81turboporsche's Avatar
Send a message via AIM to 81turboporsche
substitution of rear glass gaskets
So I just unmothballed my car. I was having a refresh done on the brakes rotors pads etc .Two of the caliper bolts stripped bare and all the o rings are toast on them .I figure that all of them will be probably the same way and I have had a set of 993 tt turbo brakes rotors an adapter kit in my basement for 2 years .while it is getting fixed i want to knock out this other big issue I have had with my car. I really am at wits end with water coming into my car from the rear window and I am looking for a solution that is a once and for all fix so I can put in my interior in and finish up my car. i have had 3 different glass companies reset the windows in change the gaskets etc . the design of the expansion gaskets really sucks i don't care about originality my car is not stock. I apologize for being all over the place I really want to daily this car again without having water splashing around my feet.
1981 911sc Coupe "Valerie" Widebody
2001 Audi S4 Avant, "The Daily Booster!"
2001 Ducati 748 Biposto "The Torture Rack"
71 Chevrolet Corvette Roadster " The Moth Ball"
Old 05-08-2017, 08:37 AM
Administrator
Dmitry at Pelican Parts's Avatar
Check out the link below, there are some helpful hints when installing the window to prevent leaks from coming in. Other members will likely make recommendations as well. Best of luck!
Porsche 911 Window Glass Installation | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 05-08-2017, 10:26 AM
I tried that route twice before and no luck with it I will prob give it a go again before I pay someone else again
Old 05-08-2017, 01:43 PM
