Slippery Slope Expert
Steam Driver's Avatar
Relay Locations
I have searched in vain for a defining diagram of the relay locations on my 1982SC. Some diagrams show more, some fewer, relays in the board over the main fuse panel. So here is an image of what I have. What are they? The empty slot on the far left is the red fuel pump relay, I know that.
Old 05-14-2017, 07:53 AM
pete3799's Avatar
Look on the inside of the fuse cover. Should be labeled.
Pete
79 911SC RoW
Old 05-14-2017, 08:00 AM
proporsche's Avatar
Hi this should help
Ivan
Old 05-14-2017, 08:05 AM
Uncertifiable!!!
Uwon's Avatar
I would not necessarily rely on any diagram. Pull each relay one by one, turn on ignition and test. I see that you have two aftermarket Bosch type relays as well located at bottom right of fuse box. Likely for hi/low beams which saves the headlight switch.
Good luck,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 05-15-2017, 03:56 AM
Flojo's Avatar
crossquestion: I deleted the heater blower and deleted rear window defog
can I just delete the rear fusepanel as well? any wireing issues?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-15-2017, 04:40 AM
