What size allen wrench do I need?
I am trying to set the fuel mixture on my SC.. what size allen is required to do this on the fuel Dist? any help on this would be great. just make sure I have it right as well
it's clockwise to richen & counter CW to lean it out. right? Allen Length? MM? Eric Mckenna 78SC w/ 83SC motor |
It's 3mm and you got it on the lean/richen directions. The length I use is about 4". My CIS tool is 6" and I can't even get it in there, way too long.
And remember to make your finnal adjustment in the CW direction. If you are leaning, you'll need to go past the point you want it at and they richen it back up to where you want it. I doesn't take much, it can be very touchy.
Thanks,
So clockwise leans it out.. and counter clockwise fattens? |
right..
Thanks... |
Eric, are you using a CO meter to make the adjustments?
Noel,
Eric is currently getting the help of his local pro for the adjustments...he should post the good news later today...smart move Eric! Get it done right! |
Eric,
if you want to borrow my CO analyzer, its fine. Hell I will even drive it up to !! It matches the dealer's CO analyzwer, so I know its calibrated. |
| All times are GMT -8. The time now is 12:07 AM. |
