DannyBNH's Avatar
Oil Pressure Sender Compatability
I have a 79 with a 3.2.
I just replaced my leaking 79 oil tank with a used 3.2 tank sourced from another pelican.
The OEL gauge went immediately up to max.
I checked the oil level and it was good.
took it for a spin and it dropped a little bit from the top but was still close it Maximum, I got the temp up to about 170 ish.
The sensor worked fine 2 days ago with the previous tank.
Any chance it's just sticking a bit ?
Is there any impact or is it just for the gauge?
At least it's not leaking anymore.
Open for suggestions..
-Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD
2015 Jeep Wrangler Sport Unlimited - White
1984 Porsche 928s Black on Black - SOLD
Old 05-24-2017, 05:40 PM
Possibly a wrong oil pressure sensor.
911SC 911-606-111-03
Carrera 911-606-135-00
Edit
Missed that it operated normally previously so not sure.
Old 05-24-2017, 06:51 PM
The 2 pressure senders are supposed to be 5 bar units. The Carrera has a pin connector and the SC has a spade connector on top.
I don't see what pressure has to do with the tank replacement
Bruce
Old 05-24-2017, 07:25 PM
DannyBNH's Avatar
Sorry meant to say OEL gauge. Oil level not pressure.
Old 05-24-2017, 08:32 PM
RETIRED
Joe Bob's Avatar
Swap in the original sender.
2012 ML350 3.0 Turbo Diesel
Old 05-24-2017, 11:10 PM
DannyBNH's Avatar
Ok cool. I wasn't sure if the pre - 3.2 tank senders were compatible with the older ones.
Old 05-25-2017, 03:35 AM
