Removing flywheel bolts, help
I am taking off my flywheel so the seal behind it can be changed. I have the tool for removing them and have wrecked three of them on the last two bolts. The splines in the bolts are still intact but the force required to break them loose is considerable and the splines on the tool bend. I do not have a torch to apply heat so I am thinking of welding a nut to allow use of a socket. Has any one any other ideas other than grinding like sugested in 101 projects.
75 targa 2.7 Lean and green |
GAFB
In my experience an impact wrench is the only way to go with these things.
Several BMWs |
Unoffended by naked girls
...And even with an impact, they're tough. I had the best luck by tightening just a little first, then they spun right out. You're not gonna believe this, but I bought a set of 12 points from autozone, and they haven't shown any sign of twisting.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
On the good bolts, I found that pounding the tool into the nut to get a good seat helped. Can offer no help on the messed up ones.
Doug '67 911 2.2 |
I could use an impact after I weld a nut on. The bolts have inner splines 12mm 12 point and I have not seen a tool like this that works on an impact.
believe it or not, just hit the top of each bolt head with a big ballpeen, or mallet. not a clawhammer, but something with some heft to it. one hard, sharp wack on each bolt, and they loosen their grip. been doing it for years. works on old vw bus lug bolts too, for what that's worth. the bolts are not re-used so have at it.
Was there any Loctite on the bolt that you did pull out? It sounds like whoever put together last, used grade "A" Loctite.
You say the spines on the tool bend? I guess it is the one-piece type. The one I have is hardened steel with a separate adapter to a square drive. I would try to find one of these two-piece sockets. Do Not weld or apply much heat to the bolts. If you Arc-Weld a nut to the bolt head, you may further bind the bolt to the crankshaft. I would use a propane torch to heat them up a bit, but nothing hotter that say 300-400 F. This would solidify the Loctite. Don’t use an oxygen/acetylene torch, as it is hard to tell how hot it is actually getting. There are high temp marking stick that you use on the surface to tell how hot you are getting, but it may be difficult to use giving the situation. Lets hope that you don’t damage the internal bolt drive surface before you get them out. Best of Luck, Keith
Keith Drive Hard and Fast 1991 Carrera 2 Targa 1972 911T Coupe 1971 914 |
Thanks for the advice, I think I will first try and find another manufacturer of the tool first then will try the ballpeen hammer. After I order some new bolts from wayne.
Success, with a better tool and a few wraps of the ballpeen the remaining bolts came out. Thanks again.
Cheers to you and a salute to John Walker!
Jim
A small turn on John's idea....get one of those hand impact drivers...it takes a square drive socket or other tool...and when you hit the back end with a mallet..it drives the tool anti-clockwise (or clockwise depending on how it is set) and in at the same time.
I have used these on motorcycle philips head screws for decades (to prevent stripping the screw) and it works great. The real benefit is that it twists and shocks the bolt at the same time. Bob
Bob Hutson |
Senior Member
JW is worth his weight in gold, and he's not a small man. I tried to deny it as a younger man but it's true....there's no substitute for experience. Also I have an impact driver like Hawgman described. You cannot work on motorcycles without one. I still use it. Can't recall it ever failing to turn the head of the fastener, when used properly. One or two whacks to seat, and then it makes an offer the fastener cannot refuse.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Banned
Guys, Where should I get one of those impact drivers? Does Sears(Craftsman) sell them, or do I need to go upmarket? TIA.
Senior Member
Any m/c shop will have them for sure. They are an absolute must to work on any Asian m/c.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Just my .02c.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
Back on topic. I use the impact, but it helps to remember JW's trick. Many sticky bolts respond to a little persuasion
I had the same problem with stuck flywheel bolts. Please get a good quality spline tool (Snap-On calls it a 'triple-square' spline). A small propane torch is good mostly because its tough to get it too hot. Heat it up, whack it good, should come right off.
Chris |
Cary, I will be replacing the bolts with new ones.
After the fly wheel was off an inspection showed the seal was not leaking but there was evidence on the oil cooler side of the casing of oil and dirt behind the flywheel. The oil was thick an gooy so it was probably there for a while and the seal looked fairly recent as it had no dirt/dust or oil on it. There also was no evidence of oil leaking from the split between the casings so I am thinking the seal was changed and whoever did it never cleaned up the casing. The first tool I was using was a one piece hex shaft made by Lisle the second one a two piece 1/2 in. drive type, I piced up at NAPA and was one of NAPA's brand name tools. The Lisle tool was definitly not up to the challenge.
75 targa 2.7 Lean and green Last edited by Paul Valcourt; 01-26-2003 at 02:57 PM.. |
flywheel seals on 911s rarely leak, even after 30 years. aircooled VWs leaked like crazy, but their cases wore out thru the mains, allowing the crank to have radial play, and compromise the seal. must be those 8 main bearings.
