Under dash turn signal/wiper plugs ID
Hi everyone! I took apart my car for a full repaint (except for the main harness) and now I am not sure how to plug each of the round connectors under the dash (wiper stalk, hi beam/turn stalk, hazard plug, etc)
Does anyone have a picture of under the dash with ID of where each round plug goes? thanks!!! cheers, Demian |
I took a photo for reference, left to right it is: turn signal plug, Hazard flasher switch plug, ignition plug
On top of it, wiper plug Empty one is where the headlight switch plug would connect Is this correct?? The plugs which have only 5 pins match...but want to be sure !!
You don't say what year car, but from another post on the subject, Jim75911S identifies the bulkhead connections on his 1975:
"On my 75 911 the plugs go as follows. Starting on the top left w/top being towards windshield and left being towards drivers door #1 headlight switch #2 emergency flasher. Next row below -#1 ? #2 wiper switch #3 ignition switch. I did not mark #1 on the lower row, when reconnecting put the one that is left over here." That would say that you have a few incorrectly installed. Sorry, I can't vouch for the information. |
