Removed AC, need to fill gaping hole...
Any ideas for how to fill this hole? It's the one to the right of the white cylinder (windshield washer pump). As you can see I filled the other hole with a piece of AL sheet metal, but this one is not flat/flush. It has a step to it that would required a shaped AL plate. Any ideas?http://forums.pelicanparts.com/uploa...1495407839.JPG
The tubs were not made with or without AC so there is a big honkin' rectangular hole under the plastic "baffle plate" on all of them. I looked up this part in the PET parts diagrams hoping to find a factory blanking plate to cover. No dice from a three minute check.
I bet you will get input from pre-SC owners that have no factory air. |
I am planning to duct fresh air to the center vents from there using a fan. Plenty of space on either side...you could sandwich two plates with a few bolts and no one would be the wiser.
Use two pieces of thinner sheet aluminum. One on the front, one on the back. Use four bolts through the two pieces while sandwiching the chassis metal. You could even use black weather stripping to seal it up.
The thinner sheet aluminum should allow some play in the metal so you can shape it to the step. -Steve |
For the Carrera one of the upgrades was standard AC on all cars. Like the bigger brakes and a 3.2 engine. It was standard equipment. |
You can use one piece of tin like you did on the other place. Just pre drill 4-6 holes in the new piece and screw them in from one side to the other and it will form to the body. Doesnt have to be air tight, but i put some sealer around mine anyway.
I tried the metal route but, ended up doing mine with a piece of plastic I cut to fit and glued in. No drilling and future removal will be easy.
I wish someone could 3 d print these so they snap in and the same for the condenser hole. I just cut out a patch and mig weld them. Takes a long time PITA.
I took one of Mrs Saucy's baking sheets, traced, cut to fit, sanded, primed, painted, riveted in...good for another 39 years...
Appreciate the kind push back rather than a flame (which I deserved). |
Ok I like the metal sandwich idea. Can do that now.
On the plastic, what type did you use? |
AC hole
I fit mine with cardboard to make a template. Then made a duplicate with aluminum. I just siliconed it in. http://forums.pelicanparts.com/uploa...1495630845.JPG
Don't make fun of my super dirty frunk! :) |
| All times are GMT -8. The time now is 06:59 AM. |
