Deleting SC sidepanels - how to handle those bores?
Hello,
as I just realigned/reset the ride hight on my SC and thus I did take the sidepanels off and as I aktually like the delete-sidepanel-look, I'm left with the bores of the screws to fix the panels. Welding them shut is not an option right now. Has anybody come up with a genious idea to plug these? Or is it just that simple: get som mini plugs and done? Or is there a narrow trim one could fit instead? Maybe you have pictures of your solution(s).. thanks! http://up.picr.de/29281421fv.jpg |
I went to local hardware store, found tiny plastic plugs, used touch up paint and painted them body color and pushed them in.
I used black rtv silicone (car is black) to fill the holes.
Flo, you have a better side view pic of the car with the 'PORSCHE' Martini stripes?
I used plastic caps that are designed to cover screw heads on kitchen units. Simple coat of paint and glue in pace. They almost looked factory
Ian |
http://forums.pelicanparts.com/porsche-911-technical-forum/795820-where-i-roll-frankfurt-am-main-6.html |
I just put rivets in the holes then touched them up with paint.
| All times are GMT -8. The time now is 07:10 AM. |
