-   -   Can anyone explain how to test the oil temperature sender? (http://forums.pelicanparts.com/porsche-911-technical-forum/957781-can-anyone-explain-how-test-oil-temperature-sender.html)
GiantRider 05-24-2017 09:44 AM
76' 911. Oil pressure side of the gauge works but the oil temperature doesn't. It rises slightly from dead bottom when I turn the car on but doesn't do anything after that.
I want to test the sender but I don't really know exactly how. Also, is there a way to test the gauge or a place to send it?
Thanks.
T77911S 05-24-2017 10:59 AM
remove wire, check gauge. short wire to ground and check gauge. should be max deflection one way and min the other. if so then sender is bad.
Porboynz 05-24-2017 09:53 PM
Boiling water is 100C
-Levi- 05-24-2017 10:33 PM
Subd
