Post your temp gauges. Humid 90s.
92 degrees + 56% humidity
Temp gauge higher than normal. Quote:
1986 Bosch Icon Wipers coupe. |
Is that driving or stationary? I don't get that high unless I'm sitting in traffic.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
with or without ac? Seems a bit higher than I'd expect to see at that temp in drier Denver without AC running (as mine's been dead for over a decade) -- mine will go over the second bar, but only around 1/3 of the way to the 3rd bar
Mighty Meatlocker Turbo
How's this temp gauge? Surface temp of left, front fender - car in garage, fully shaded (including car port in front of garage = more shade than typical home garage), has not been in the sun today. High was 107 humidity of 56%.
Woody, your car's oil temp gauge looks like mine (maybe just slightly higher) for most of the year around here - turbo powaaa' and a/c on high, buttofcourse.
That is the highest it's ever gotten.
Mine is usually right at the first line. But, there is some heat warning in NY. The humidity makes it feel like 105-110.
Sugarwood, this is after about an hour of driving in Hotlanta at night, ambient temp about 85F, and humidity through the roof as per usual here.
![]() In the wintertime with ambient temp at 50-55F, I barely make it past the first white line (194F). Hope you're not nervous. You shouldn't be. Ambient temp has a lot to do with it. Whenever I get nervous about temps I look at this pic again, anything short of the second white line (248F) is "Normal". ![]() Cheers
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" Last edited by Franks89-911; 08-13-2016 at 07:12 AM.. |
Thanks. Wasn't nervous, just sharing my experience.
I chased that for a while...thought it was the a/c loading it too much. Thought it was the front oil cooler in the wheel well or its thermostat in the right rear wheel well. Both good. Installed a manual switch in the car to turn on the right front cooling fan as well as put in the BMW lower temp switch to activate that fan.
Still had the issue. Replaced the engine mounted oil cooler and it fixed it...nice and cool into the 90s and low 100s...oil temp around 205F
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
I drove to work yesterday and the temp gauge was in the usual position.
Slightly below the first line (194*) when the temp was 65* On the drive home, the temp was around 80* with 50% humidity. On the highway, it was exactly on the first line. Near the end, after a little stop and go traffic light driving, I noticed it was riding above the first line again. Is this normal? I don't remember seeing it go past the first line when it's only 80* out.
Driver, not Mechanic
I get that temp (first pic) when it's above 90 and a/c is on.
I get the one above when it's 70s or 80s and it's a 15 minute drive. |
Highway driving at 94F
my 930. not 90 but normal for hot days....sitting in traffic.
Engine temps...........
I don't have a picture, but my SC generally runs between 190 and 210 degrees F. Running the air doesn't seem to make too much difference. Here in South Georgia the ambient temps usually run between 90 and 100+ all summer and into the fall. I do have a large Setrab brand cooler mounted in place of the trombone cooler but I seldom feel the need to turn on the fan that blows thru it.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
I'll post mostly because I have a pic. This steady-state 45 mph or so in ~90F weather. Front-mounted Setrab cooler.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
