Len 911's Avatar
Washers got trans mounts
I am replacing the trans mounts and previous owner did not put the correct washers in.. does the trans mount take the same curved washer as the motor mounts do..if so I am missing them.. so i will need 4 correct?
I see pelican sells thick washers for the mounts is that all I need or should I install the curved ones.
85 911 3.2
Len
Old 05-26-2017, 12:08 PM
proporsche's Avatar
Hi Len
for the trany you only need 2 washers.And yes the same as engine mounts..
Ivan
Old 05-26-2017, 12:44 PM
Len 911's Avatar
Two per side..or one on just the bottom side neat the bolt head
Old 05-26-2017, 01:38 PM
proporsche's Avatar
hi..just two on the bottom..
Ivan
Old 05-26-2017, 02:01 PM
Len 911's Avatar
Thank you..
Old 05-26-2017, 03:45 PM
81SC's Avatar
Per the technical bulletin.
81SC Coupe
Tony Kart/Yamaha
Old 05-26-2017, 05:20 PM
proporsche's Avatar
Hi to Australia...yes i remember this bulletin....back in the 1980`s a lot of mechanics used the air impact gun to install the trany and engine back into the car.I have seen plenty of stripped threads because of this.
We have decided(at the shop) then to use only one washer on bottom.The origin is 4 ...by the specs...i use only 2 ...per trany mount..i like the when the mounts meet solid with the body.
Ivan
Len ,you might want to use 4 ...so i do not mislead you;-)
Old 05-27-2017, 12:48 AM
Send a message via Skype™ to Porboynz
Having suffered a stripped thread that had to be helicoiled I recommend threading the bolt in by hand until it bottoms out, then wind it out one full turn. Measure the exposed shank length of the bolt and make sure that whatever your combination of mount and washers is the bolt cannot bottom out.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-27-2017, 10:30 PM
