-   -   Final Stages of Rebuild/Installation and have hit a snag... (http://forums.pelicanparts.com/porsche-911-technical-forum/958093-final-stages-rebuild-installation-have-hit-snag.html)
CarreraWSJT 05-26-2017 07:51 PM
I'm nearing the end of an extremely long rebuild to my 3.2L '87 911 Coupe and I've hit a snag with two items:
1) Clutch Slave Cylinder - In my haste to get the engine installed I missed putting the slave cylinder on to the transmission prior to mounting the engine. So as I was working above my head trying to get the slave cylinder installed I forced the "rod" through the side of the rubber boot and tore a hole in it. I've searched on Pelican and can't see that the boot is available as a standalone item so my question is do I have to replace the entire slave cylinder or can I get a replacement boot.
2) I have a hose that comes off of the recirculating air valve but for the life of me I can see where I need to attach on the other end. Any assistance is greatly appreciated!
http://forums.pelicanparts.com/uploa...1495853107.JPG
sc_rufctr 05-26-2017 08:15 PM
Can't help with the hose but is there a part number on the rubber boot?
Flat6pac 05-27-2017 03:51 AM
The small hose attaches to the front of the throttle body. It is supported by the hose support on the corner of the air cleaner box.
Bruce
JRSIII 05-27-2017 05:06 AM
Just to clarify...regarding question 2...are you asking about the small rubber hose that is not yet connected to the valve or the braided hose shown? In either case, there is a schematic of the system in the Bentley manual page 100-4.
shadowjack1 05-27-2017 05:26 AM
I looked for a part number but no luck. It looks like you have to buy the whole unit. Maybe someone else will chime in with what you need, Lots of luck.
steely 05-27-2017 06:15 AM
I'd recommend just replacing the slave cyl - mine got to be quite stiff to operate, even with an intact boot.
check just underneath your deck lid for a decal for the hose location,
CarreraWSJT 05-27-2017 07:26 AM
The braided tubing is the one I can't locate. I'm looking in the Bentley manual (100-4) but still can't locate where the tubing terminates.
CarreraWSJT 05-27-2017 07:30 AM
Bruce
It is the braided tubing above the rubber hose I am referring to. The rubber hose is supported by the air cleaner box but the braided tubing is free floating.
JRSIII 05-27-2017 07:41 AM
The braided hose is vacuum. That valve is activated via a temperature switch on the back of the throttle body that opens the valve at a certain temperature. The switch is right under the big elbow above the throttle body. It's very difficult to see with engine in car but you can with a swiveling mirror on a stick, I could try to take a picture but can't post it until tues when I'm back in office,
CarreraWSJT 05-27-2017 07:43 AM
Found the spot the braided tubing goes. Thanks all - now to sort out the slave cylinder!
