Slate Grey 6801 in PPG paint
I've been searching the net and these forums, but with no luck:
My friend who does paint and body work uses PPG paints. I haven't been able to find a code or formula he can use for slate grey 6801 in PPG. I'm a rookie when it comes to paint, so any input is appreciated
Fleabit peanut monkey
Just as a side note and I am aware this is not what you are asking. If you are looking for the Steve McQueen's 930 slate gray it's a 356 color. Glasurit 615 Slate Gray.
1981 911SC Targa |
Does that mean I need to purchase the paint from Glasurit? Sorry for the ignorance… I just want to make sure to get this right.
Glasurit is your source color. The factory paint starting point. You do not have to buy Glasurit paint. You want to find the PPG mix/blend that is the same as Glasurit 6801. You are asking no more than that, correct? If you HAPPEN to be wanting the Steve McQueen 1976 930 Slate Gray it's Porsche 356 Glasurit 615. That's all I am saying. There is probably a PPG formula for that somewhere.
1981 911SC Targa |
That is exactly what I'm asking, Bob. Thank you for articulating it. I like the Porsche 6801. I've been searching for it and haven't been able to find any PPG formula.
Occasional User
You might try posting in the Paint & Bodywork forum. Porsche962 is a guru, he may know. Although I seem to recall he is not a fan of PPG. Just an idea.
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
Don't mention Sikkens either.
1981 911SC Targa |
Thanks for the tip. Will do!
Good luck getting that color. I had three differant paint suppliers try and make it with PPG and none of them looked right. I was building a hot rod and it was for the bumpers only so I lived with it. But they all had a hard time trying to convert the formula.
78 911 st backdate 87 944 00 996 |
If it's not a show car BASF LIMCO is an option. BASF also has a single stage urethane that can be matched to 6801. This is in the Glasurit family.
1981 911SC Targa |
Thanks all. I'll look at something other than PPG.
I tried to use PPG also. The local guy called PPG paint library guys and they said they couldn't do it.
2001 986 S |
Edit: OP posted in Paint and Bodywork forum. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/958174-6801-paint-code-formula.html
1981 911SC Targa Last edited by Bob Kontak; 05-28-2017 at 10:46 AM.. |
