-   -   lets see above tunnel throttle cables! (http://forums.pelicanparts.com/porsche-911-technical-forum/958147-lets-see-above-tunnel-throttle-cables.html)
petercoetzee 05-27-2017 02:09 PM
So, amidst wrestling with my own cable route & feel, Ive been considering alternatives. Including gt3 style in-sheath cables. Then this popped up on instagram and got me thinking...
Anyone else tried this?
http://forums.pelicanparts.com/uploa...1495919356.jpg
Sebscst 05-27-2017 05:12 PM
That looks cool.
hcoles 05-27-2017 07:54 PM
I like it but probably won't work it is too simple. :-)
BTW - I was just in Cape Town and hiked up Table Mountain.
911pcars 05-28-2017 12:03 AM
Many contemporary cars have adopted throttle-by-wire throttle control. Before that, throttle actuation was by cable. Before that, there was mechanical linkage. The solution for early Porsches is thus to upgrade to an old-fashion cable.
The issue is finding a the correct length cable and perhaps fabricating or adapting the mechanical stop and bits at the throttle end.
All this should fit comfortably inside the tunnel. However, having everything exposed makes adjustments easier if one doesn't mind the "clutter" of mechanical bits next to your foot/leg. Are you thinking of exposing the clutch linkage too?
Sherwood
tobluforu 05-28-2017 03:18 AM
Sherwood
I was about to change to a cable but could not figure out how incorporate the hand throttle.
911pcars 05-28-2017 08:25 AM
You could remove a section of sheathing below the hand throttle lever to expose the cable, then apply an equivalent mechanical cable stop and lever arrangement. Other adjuster bits may be necessary to support the flexible cable at that location.
Sherwood
Mahler9th 05-28-2017 11:16 AM
JWE has developed a cable system like this that is installed on several SPEC 911 cars. A special gas pedal is part of this system.
I suspect that it is/will be used on the GTL (a special Porsche Racing Club GT class that is growing rapidly) car they build. It is pretty well sorted out. Not sure whether its available as a kit of parts, but I suspect that it might be available to another shop.
901 shop in Florida list a kit for $550.
SpyderMike 05-28-2017 11:44 AM
I used these folks for a custom cable for my airplane project...not that expensive:
Control Cables | Industrial Motion Controls | Street Rod Parts & Accessories
