Arlo911's Avatar
Possible to replace brake booster with master cylinder in place?
Long story short, the brake booster on my fathers' SC doesn't work.
I found a replacement, but wanted to know if it's possible to replace it while leaving the master cylinder in place, so I don't have to bleed the brakes.
Early S member #1969
Old 05-28-2017, 01:32 AM
I asked this question a few years back and didn't get a definitive answer - the sense seemed to be that it would probably work.
Before you go to the trouble, check to see if the problem is in fact with the booster - it's a pretty robust part and rarely fails. I thought mine was cooked, but it turns out the vacuum line was damaged. Disconnect the line where it enters the trunk and check to see if you're drawing vacuum.
Old 05-28-2017, 06:12 AM
Arlo911's Avatar
Yes I tried that and I have vacuum there...
At first I thought it was because of the bremtek brakes, but since I've fitted standard SC brakes there's still no change.
Old 05-28-2017, 07:10 AM
Also check the brake pedal itself. Mine was binding and I wasn't getting the full travel. Very hard pedal. I was pretty convinced it was the booster but it wasn't.
Old 05-28-2017, 06:45 PM
emac's Avatar
Nope
Ernie
Old 05-28-2017, 07:37 PM
ROW '78 911 Targa
timmy2's Avatar
How old are the rubber brake lines?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-28-2017, 09:11 PM
Arlo911's Avatar
Brake lines are new, calipers are new, brake fluid is fresh. I'll try and see where I end
Old 05-28-2017, 10:58 PM
You can swap the booster and master as a unit You will have to bleed the brakes
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 05-29-2017, 07:49 AM
Arlo911's Avatar
Quick update:
-Turns out I had a vacuum leak at the hard line that comes out of the transmission tunnel, there was a chunk of metal missing, go figure... So before you change out your booster, check for vacuum leaks where you least expect them
-BUT: I learned it IS possible to replace the brake booster without having to bleed the brakes.
Old 12-29-2017, 01:05 PM
T77911S's Avatar
that's what I was going to suggest.
pull a vacuum on the booster and see if it holds.
if it does, connect it back up, then pull a vacuum on the line back at the engine bay,
this is a good check to do anyway as you can have a vacuum leak, the booster still works but it will effect the engine.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-03-2018, 09:13 AM
