Help identify oil hose leak 911 3.2
Hi,
Can someone help identify the oil hose below (part#). It is weeping and doesn't look genuine to me. To replace do I need to lower the engine or can be done in situ? TIA, Oemar
Hi there
this is the line you need to get part number is 93010734714 To replace it set your engine on top Z1. Remove the air-duck pipe then remove the distributor,Make sure you put some plug in the hole so nothing falls inside the engine and replace the line.Also get your self 2 new alu. washers for the oil through bolt. Ivan Make sure you install the distributor in correctly...
Hi ,if you get the oil line from here or Porsche dealer it should have the end ring and nut.
The number is more likely updated to the 14.... Ivan |
Ok thank you so much. Is it safe to continue driving the car now?
1988 Carrera
I would drive it. But keep an eye on it as well.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Counterclockwise?
I'm having a hard time figuring out the location, but it looks like a vacuum line with a hose clamp on it.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
As proporsche said.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
