MFI thermostat connection
What do people connect the hot air side of the MFI pump thermostat hot air
input to if you have a straight racing exhaust without heat exchangers?
thanks
-phil
Old 08-15-2017, 03:20 PM
You need to go to a manual screw.
The stock heat exchangers have a tube which feeds hot air to the tube. You could also fabricate a small heat exchanger around the collector.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-15-2017, 04:53 PM
Functionista
manbridge 74's Avatar
Years ago I read that the factory would use a small bulb under the thermostat in an enclosure on header equipped race cars. I believe it was Roland Kunz who relayed this info. I don't believe he has posted in years.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-15-2017, 05:26 PM
Functionista
And of course Supertec sells the cable actuated enrichment lever set up.
Jeff
74 911, #3
Old 08-15-2017, 06:55 PM
you remove the thermostat and build and aluminum plate to cover the area. Duplicate the base of the thermostat housing.
Drill a hole in it for a 6mm screw, install a steel helicoil. INsert a 6mm bolt and use this to adjust overall mixture of the MFI.
I did this years ago on my 2.7 and it is a great mod.
Just remember that you have to push the lever in with the screw or the MFI will run way rich like a cold day!!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-15-2017, 08:39 PM
I will give supertec a call -- I have the handbrake choke lever unused ...
Old 08-16-2017, 02:03 PM
