Friend of Warren
What Wiring is missing from this 964 Lid
I am looking at buying this 964 lid. Looking at the photo it looks like it might be missing two wire connections as shown in the following photo (circled in red).
I believe one connection is the one that runs up to the cockpit to open and close the spoiler, but the other one, as shown below circled in blue, appears to run somewhere into the spoiler. What does it do and where can I get one? Don't want to buy the tail and find out I need to spend another $100 to get it to work.
Kurt V No more Porsches, but a revolving number of motorcycles. |
hallo Kurt
You are missing the Hood- Body harness that connects to the main harness in the Engine Bay , it has the power for the light too . Partnr:96461204903 Do you sit ? That little thingy is 200 $ Harald |
Insert Tag Line HERE.....
>>That little thingy is 200 $<<
You don't need it though. Simply run your own wiring to the motor and 3rd brake light. There is a cover missing over the gear mechanism also, and you dont need the wiring to the two micro switches on the gears either. (they allow it to work electronically through the computer)
Marc |
If you want to hook it to a window controller, you will need the microswitch wires.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
