adamb113's Avatar
waxing your rims after polishing
I see in the "polishing your rims" article that it gives the option of waxing your newly polished rims or clear coating them.
What kind of wax should I use if I'm going with that option?
Regular car wax?
Thanks,
Adam
1973 911 T Targa
Old 05-26-2005, 08:56 AM
glenndeweirdt's Avatar
I like to use turtle wax black colored wax on my black centered Fuchs. Works well. Vaseline looks good too.
PCA National, BMW Club, SCCA HPDE Instructor. MSF Level 2
'23 BMW 540 iX (wife's driver)
'14 Cayenne Diesel DD and tow vehicle
'16 GT4
'22 911 Date night vehicle
Old 05-26-2005, 09:03 AM
There's a wax specifically formulated for wheels called "Wheel Wax"
I've been using it and I'm quite please. I seems to endure the heat a bit better than plain ole wax.
Warren & Ron, may you rest in Peace.
Old 05-26-2005, 09:11 AM
Try Rejex.
Old 05-26-2005, 09:26 AM
Hilbilly Deluxe
emcon5's Avatar
Mine have a extra special powdered sealer. Brake dust.
Tom
82 911SC Coupe
GTI Cup #43
Old 05-26-2005, 09:46 AM
Unregistered
sammyg2's Avatar
I use Wenol blue on my rims. It is a fine polish but also contains carnuba (sp?) wax, according to guy who sells the stuff.
The red version is more harsh and does not contain the wax.
BTW I think it is available through our host
Old 05-26-2005, 10:47 AM
adamb113's Avatar
Am I risking anything by using regular Carnuba car wax at first and later upgrading to a "specialized" wax?
How long will the regular car wax last?
Are you guys waxing over clear coats or raw polished metal?
1973 911 T Targa
Old 05-26-2005, 11:01 AM
Unregistered
sammyg2's Avatar
Raw polished metal on my wheels.
The wenol blue doesn't keep the wheels from getting dirty but it helps slow down the corrosion so I don't have to polish them as often and when i do polish them it doesn't take as long when compared to regular polish like mothers or something.
Old 05-26-2005, 11:07 AM
Recreational User
porschenut's Avatar
If the surface is anodized, use vaseline. If it is painted (clear coat or not), use wax. But carnauba-based waxes aren't the best choice for wheels because they're not very durable. Use a good wheel wax.
Old 05-26-2005, 11:30 AM
I've used Pure Yellow Carnuba and Wheel Wax on polished raw, polished aluminum wheels and on polioshed, clear coated wheels. I experienced no problems with the yellow carnuba. I've also had similar results/experience to sammy's.
The easiest/quickest way to maintain the shine on raw polished wheels is to use "Never Dull", a chemically treated cotton wadding product. I noticed that Walmart now sells. A more aggressive polish will be necessary if the metal is not maintained.
Old 05-26-2005, 11:43 AM
adamb113's Avatar
What happens when you go to polish a waxed wheel? Do you have to remove the wax first or does the polishing remove it?
1973 911 T Targa
Old 05-26-2005, 11:45 AM
