What insert fits a Bilstein RSR strut body?
Just want to confirm what inserts will fit a Bilstein RSR strut (see below). Can I use bilstein inserts from the normal stock Bilstein stut body? I know valving will be different but am going to get them revalved anyways, so looking for physical fit.
Thanks. http://forums.pelicanparts.com/uploa...1496404025.png |
99% sure all the inverted struts (with the roll pin on the bottom) are the same dimensions. Bilstein and the Ohlins should fit.
Not sure if the new KW housings are Bilstein compatible or not. |
Yep that's what I was thinking as well, would make a lot of sense to do it this way. Just wanted to confirm.
BTW I love that others are on this board at 8 AM, as I dial into a conference call at work :)
| All times are GMT -8. The time now is 12:31 AM. |
