mingmong's Avatar
Very very smokey start up
Hi all,
I've just attempted to start up my 1977 2.7S. It's been sitting in the garage for about a year and half. Worked perfectly when it was parked up but today it was a start up disaster! Engine fired up without any trouble. Idled nicely around 1K, backfired a couple of times when I revved gently to pull out of the garage but goodness did it smoke! It smoked and smoked and smoked some more! Normally I'd expect a little puff and because it's been unused I'd expect a little smoke (engine's got a tiny leak over the heat exchangers so this would burn off when they warmed up) but no..this was something else. Smoke literally pouring out the exhaust. Completely filled the garage and I got lot's of concerned looks from drivers and passerby's. I let the engine idle for about 5 minutes but it just carried on smoking away, embarrassing me more and more. Revved it to 3K a couple of times too but no change there either, just more smoke Gave up in the end as I thought someone would probably call the fire brigade! What do you think this could mean? Broken piston rings? Engine rebuild o'clock? Or should I have just idled it for longer? Any suggestions greatly appreciated as always. -Mark
Old 02-26-2016, 03:10 AM
billh1963's Avatar
Probably Oil leaked into the exhaust. You can either drive it until it burns out or remove the exhaust and clean it out.
There are other potential culprits, of course. However, if the car was running good when parked and still runs good now that is the most likely scenario.
Old 02-26-2016, 03:21 AM
mingmong's Avatar
Thanks Bill..you've settled my mind from the shock of so much smoke! I'll try again soon and see if I can bear the dirty looks from the neighbors! -M
Old 02-26-2016, 03:59 AM
Both my 911's smoke on startup after sitting for a few days. Dissipates quickly and they run fine.
No smoke for startups on same day. I keep the oil levels half way between the high and low marks so I assume the oil seepage into the exhaust scenario is in play. I don't worry about it.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 02-26-2016, 04:30 AM
BillH -
Exactly how does oil leave the engine and fill up the exhaust during storage?
- Rob
Old 02-26-2016, 05:45 AM
After a long period of sitting the oil in the lower part of the engine can seep past the rings on the pistons and collect in the combustion chamber then into the exhaust. The oil on top of the cylinder can seep past the valve stem seals causing the same issue. If you have overfilled the oil tank that too can exacerbate the problem.
Old 02-26-2016, 05:57 AM
Gomez O -
Don't you think hydraulic lock would occur the first time the engine turned over if this were the case?
- Rob
Old 02-26-2016, 06:01 AM
billh1963's Avatar
Originally Posted by Robert59095 View Post
Gomez O -
- Rob
No...this is actually well documented. People much more knowledgeable than me have discussed the issue and I recently saw a thread about it.
Old 02-26-2016, 06:08 AM
My reshly rebuilt 3.2 occasionally smokes no start up after siting for a few days. People make a check valve that closes to prevent gravity from draining oil from the oil tank into the engine when the engine it's off to prevent this. Some people donor like the idea of this thoug, they fear the valve getting stuck closed and cutting off supply of oil to your engine.
It's simply a querk of these cars. If it starts happening badly, after every start....once you get the current oil slick cleaned out....then it old be tower things. I say take I for a drive, and drive it until it stops smoking. Highway would be great.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 02-26-2016, 07:10 AM
Mine sat for 8 months and smoked like crazy for about 10 mins. Completely fine now.
Old 02-26-2016, 09:04 AM
take it out at night if you dont want dirty looks. Me I like the attention lol
Old 02-26-2016, 09:41 AM
Gomez O -
- Rob
Good question but we're talking about a couple of mill's of oil in maybe two or three cylinders.
Old 02-26-2016, 11:52 AM
Derek911's Avatar
Try an oil check valve like the one from
Rothsport. Eliminates oil migration from cars that sit a long time. Sold on Pelican as well.
Welcome to Rothsport Racing
Old 02-26-2016, 07:12 PM
Bulldog9's Avatar
My XS11 motorcycle does this because of a bad exhaust valve seal/stem. Go for a drive, if it is oil that settled through the valve stems, or rings while sitting, it will burn off in 5-10 minutes of driving. If it still smokes, likely a broken oil ring, or valve stem/seal. Is your oil level right?
1976 Porsche 912E http://www.912bbs.org/vb/showthread.php?43391-770-Update
1989 Porsche 944 S2
2020 Mustang Bullitt
Buncha Moto Guzzi Motorcycles
Old 02-26-2016, 07:29 PM
mingmong's Avatar
Thanks for your advice everyone. Just started it up again today. Smoked a little to start but no where near as badly as before. Idled smoothly for 20mins and then no more smoke. Oil pressure good and level correct. Revved smoothly to 5K with no backfiring. Forgotten how lovely these engines sound! Now comes the next part...new headliner install and stereo backdate. Looking forward to it!
Old 02-29-2016, 03:01 AM
scarceller's Avatar
How full is the oil level? At idle fully warm check the dip stick, if it's in the 1/2 to full area I suggest taking out a tad of oil. I found that running these cars at 1/4 full on the dip stick tends to keep the intake cleaner.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-29-2016, 08:05 AM
I reiterate.....just needs an "Italian Tune-Up" out on the freeway.
Old 02-29-2016, 02:48 PM
sugarwood's Avatar
Take it out for a drive!
1986 Bosch Icon Wipers coupe.
Old 02-29-2016, 04:34 PM
scarceller's Avatar
Check the breather pipe from the oil tank to the Air Box, how dirty (oily) is it at the air box end? Did any oil get into the air box?
Sal
1964 356SC (SOLD)
Old 03-01-2016, 04:55 AM
realgren's Avatar
Start it and drive it. Don't let it sit in your driveway
Jerome
1987 911 Carrera
3.5l, twin plug, turbo, LSD and more
www.310Engineering.com
Old 03-01-2016, 12:20 PM
