-   -   h4 assembly mounting (http://forums.pelicanparts.com/porsche-911-technical-forum/958921-h4-assembly-mounting.html)
kanadary 06-03-2017 07:25 PM
not sure if this has been talked about before but i figured out a very easy way to install the H4s into the buckets without hit and miss of the mounting screw. i didn't clip the top part of the ring to the bucket and just started the screw at the base, maybe half a turn, just so that its seated, then lift the assembly and secure the lip of the ring to the bucket, then tighten the screw. i messed up a pair of rings by removing the plastic spacer from behind the screw cause i wasn't able to line up the screw with the mounting hole.
