Shift coupler bushings
I happened to find some shift coupler bushings in my box of parts. My question, is it really that hard to change them?I see that some recommend replacing the whole shift coupler and not bothering with the task.Any input appreciated.
I would rather be driving
Very easy to replace.
But if you have a shifter front console it will take extra time to remove it for access to the shifter. Pelican Technical Article: Shifting Improvements - 911 (1965-86) - 930 Turbo (1975-86)
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The shift coupler bushing is not under the front console it's between the seats in the back (access plate)
83 911 Production Cab #10
Of course the press will cost you more than getting this one... Shift Coupler with new bushing and cone set screw
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Brew Master
It's so easy a caveman could do it.
![]() Seriously it's really easy. If you look on youtube Ed (the coupler whisperer) has a how to video. I rebuilt two of them and kept one for a spare although I seriously doubt I'll need it for no more than my car gets driven and the fact that I used the brass bushings in the one I put in. https://www.youtube.com/watch?v=LAD0PoC8mzo |
I replaced mine easily
If you don't have access to the equipment to replace the bushing, I would recommend replacing the whole shift coupler. I got a Wevo coupler and it was very easy to install.
1986 911 3.2 Cabriolet "We all have a desire to create something that will show we were here. " Ferry Porsche |
Baseline to stock and then make changes from there. I often see the shift rod support bushing have more wear than the rear shift coupler.
SC Mutt
I did mine and it was ok. I was not happy with the result so I went with the coupler whisperer. He makes his own. U shines and for the small price on such an important part of the driving experience I would have him do it.
My 2 cents |
SC Mutt
Spell check. Still on pain meds. "He makes his own bushings"
Thank you gentlemen
Low Class Yuppie
I was unaware that I needed a press when I did mine. I ran up the street and had a shop press the new ones in. I bought them a pizza for their trouble. Overall it was pretty easy. My old bushings were a nice oval shape!
-Cam 1984 Porsche 911 Carrera Coupe "Porsche ownership is like AA. You can be a hedge fund manager or a stock boy at Menard's. Nobody cares. Common ground." -Bob Kontak |
No press needed. I used a vise, a few punches, and a hammer. Coupler Removal, bushing replacement, and installation back into the car took less than 20 min. This was my first time doing it and I watched the YouTube video first.
Banned but not out, yet..
Just replaced mine with the Stromski unit sold by our host. I now get a grinding noise in first and second in the shifter. How should I adjust this?
An air cooled refrigerator. ‘Mein Teil’ |
There is a collar on the shift rod that can be loosened so you can slide the rod in and out of the coupler to get the ideal adjustment.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
It will help to have help. Much easier with four hands.
OK, all work is done in such small places... how do another set of hands help?
Wayne 1980 911 SC 1960 MGA 1600 |
The other hands can move the shifter lever slightly in the direction you need to adjust, or hold shifter right where you need it when you tighten down coupler end. If you have long arms you can do it alone.
Hello
I read the 911 bushings are oval and the 914 are round. Does anyone have the part # for the round 914 bushing , link to it? What material is this made of? My car is apart and now is the time to replace the original part. Was there a write up on why the OE are oval? Thanks BTW- I hear there are bushings made of Polygrahite and Derlin. What is the verdict from actual users? Last edited by How2; 05-26-2017 at 06:12 PM.. Reason: more info |
