1984 ,911 wont start some help
I used the car about 2 weeks ago, and works perfect
now i try to used today but it crancks but wont startup, it have 1/2 tank of gas, I check the battery and was low so I use a jumper from my other car, and again it crancks but don`t startup, I used an battery jumper 750 crancking power, but again
wont start
some help please, what I need to check?
Old 06-10-2017, 10:48 AM
ck main relay, under driver seat next to the ECU
Old 06-10-2017, 11:10 AM
I check and I don`t have spark on spark plugs, but I do have spark in the coil
Old 06-10-2017, 12:17 PM
Rotor, Cap, Plug wires, coil wire, Spark plugs. I had magnecore wires come apart at the plug connectors.
Old 06-11-2017, 09:10 PM
Administrator
Luccia at Pelican Parts's Avatar
When's the last time you replaced your ignition components? One of the most common problems with the older cars is that owners don't change the ignition components often enough. Some more info here: Porsche 911 Ignition Tune-Up | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article. Good luck! Hope you get it figured out quickly.
Old 06-12-2017, 09:56 AM
JTL JTL is offline
JTL's Avatar
If no spark check the flywheel sensors. I'll bet one of those has given up the ghost.
Cheers, Jt
-84 911 targa
Old 06-12-2017, 11:39 AM
