-   -   Vacuum line clarification (http://forums.pelicanparts.com/porsche-911-technical-forum/959894-vacuum-line-clarification.html)
flat6_911 06-12-2017 03:32 PM
Hi everyone, i own a 1982 911SC.
Never really ran 100% but it ran fair enough to daily drive. Idle has always been a bit inconsistent.
Now its bucking and makes driving unpleasant. Idle is always surging.
Ive searched the forums for a good couple months to gather as much info as i could. One thing i cant seem to find is pictures of vacuum lines.
Ive followed the vacuum diagrams and it doesn't match to what i have on the car.
I mapped out my lines and i just want some input before i dig any deeper.
https://uploads.tapatalk-cdn.com/201...e7cf948fd1.jpg
Does that seem normal? The vac diagrams i seen never showed how to plumb the WUR vac?
Thanks for any help [emoji106]
Sent from my iPad using Tapatalk Pro
flat6_911 06-12-2017 03:34 PM
The car itself
https://uploads.tapatalk-cdn.com/201...dcac4d5ef9.jpg
SkiVT 06-12-2017 03:56 PM
Originally Posted by flat6_911 (Post 9623545)
The car itself
http://forums.pelicanparts.com/uploa...1497308169.jpg
If its a euro engine, this diagram is it.
Flat6pac 06-12-2017 03:59 PM
There should be a vacuum map inside the motor cover
Should have a red and blue line coming off the throttle body to the distributor.
On the 80 to 83 there is 2 connections on the distributor pod.
The one closest to you at the motor is advance the one on the back of the pod is retard.
If the hoses are hooked correctly, at idle, one hose will have vacuum. You can tell by putting the hose to your tongue, the vacuum goes to the retard side of the pod. It has vacuum at idle because the port on the TB is located below the butterfly and the running engine is looking for all the air it can get.
The advance gets vacuum from the air rush into the engine at high speed causing advance in the distributor. The vacuum connection is located above the butterfly.
Bruce
arbita1 06-12-2017 04:47 PM
Something seems off on your diagram. Does your car have cruise control.
flat6_911 06-12-2017 04:55 PM
Car is ROW, it does have cruise control but i never used it. Ill have a look tonight to see how its hooked up.
Flat6pac 06-12-2017 05:28 PM
Cruise hooks into the power brake line to the small hose
Large hose goes into the shock top retainer.
Bruce
SkiVT 06-12-2017 05:52 PM
Last 3 digits on your WUR 089? If so, the vacuum is the side outlet. Top outlet is atmosphere and I dont think needs to connect to anything.
flat6_911 06-12-2017 06:31 PM
Wur 0-438-140-072
bugstrider 06-12-2017 07:53 PM
Do you have an EGR? Our 78SC developed a surge/buck at 3000-3500 rpm. Turned out to be a vacuum leak due to the internal diaphragm that failed and is non serviceable.
boyt911sc 06-12-2017 08:30 PM
Wrong WUR.......
Originally Posted by flat6_911 (Post 9623763)
Wur 0-438-140-072
No wonder you are having problems with your vacuum lines. WUR-072 is a non-vacuum assisted and used in USA '80 SC CIS engines. And your engine is RoW. You have the wrong WUR. Even your sketch (first drawing) shows some inconsistencies.
Let's start from the beginning. Identify your CIS components.
WUR-072
FD-???
AAR-???
Ignition distributor-???
Etc.
Keep us posted.
Tony
SkiVT 06-13-2017 02:52 AM
Posting a picture of the fuel lines at the WUR may also hep. My ROW had the wrong WUR and some added lines from being federalized when imported. Those added elements caused prolems that were difficult to diagnose as they are not OE.
flat6_911 06-13-2017 03:34 AM
Oops I apologize, I thought non-euro cars were called ROW. But its non-US that are ROW?
My car came from alabama. So its a US '83
Noob mistake. Ill get the other part numbers shortly
SkiVT 06-13-2017 04:36 AM
Yes, generally non-US are ROW euro. Post your engine number to be sure. I think 930/10 is 1983 euro. I dont recall the US engine number.
flat6_911 06-13-2017 04:51 AM
FD: 0438100077
Engine: 64C2467
What seems odd to me is that i have 1 vac line coming off of the WUR going to a "T" that connects to the T.B above the butterfly and it T's off to another line connecting to a port below butterfly.
Wouldn't that throw off the WUR?
WUR;
https://uploads.tapatalk-cdn.com/201...6edd77634d.jpg
Cruise control; (the big vac line vents to atmosphere, there isnt anything hooked up on the small vacuum line)
https://uploads.tapatalk-cdn.com/201...ed67a76066.jpg
T77911S 06-13-2017 05:36 AM
WUR-072
FD-???
AAR-???
Etc.
Keep us posted.
Tony
correct.
the drawing has 2 lines from the TB going to the WUR and DV.
tony will get you there
boyt911sc 06-13-2017 06:12 AM
A lot of inconsistencies.......
Could you post additional information like:
Engine type: 930/??
Vin number:?????
The Red Book shows engine 64C2467 is from an '82 SC targa US model. Knowing the engine type and VIN # would narrow down our identication process. At this point, I would say this is a late SC engine US model. What you need is to know and understand how the vacuum lines are connected.
Tony
flat6_911 06-13-2017 06:26 AM
Vin: WPOAA0917CS121291
Ill get the engine type in a bit.
Thanks again, really appreciate the help
T77911S 06-13-2017 08:15 AM
the port below the butterfly is for the vacuum control to the WUR. this is usually T'd with the DV.
if it is US engine does it have any lambda stuff on it.
if you have euro CIS on it then you need the parts for THAT system. match the parts to the CIS, not the engine.
read flat6pac's post for dist vacuum lines.
one thing, if you remove the retard line at idle, the idle should go up.
if you swap the retard line to the advance port at idle, the idle should go up.
this is a very easy check that verifies lines and ports on the dist and that they work.
flat6_911 06-13-2017 08:32 AM
Yup its got everything lambda, PO told me it had all the stock components. Just doing a double check to make sure.
From what i can gather the WUR-072 should vent to atmosphere? So that vac line should be connected above butterfly if anything?
I dont really plan on using cruise control, if i leave the nipple open on the cruise control module would it affect anything?
