911 2.0 68 Karmann (decode) the code ))) help! 11825100
hi/ciao, please 1 friend i like to buy one 2.0 SWB Karman whit this frame/vin code: 11825100 ist good?...i have 3.2..i am "not expert" pre bumpers...
VIN fits to your description. Decodes as model year 68, 911 T coupe Karmann (original engine 2.0 litre with 110 HP). No US-model. It's # 100 from 683 in total.
Thanks!
please Stahler if possible....this car...fit 2.4T engine...and gearbox 911/10 (2.2 E 70..?)
What are the correct engine and gear codes? engine (carbs?...solex...zenith..weber?...marelli or bosch distributor?) 4 or 5 gears? (5° optional?) very very thanks an advance |
according to my records:
engine number should be between 2080001 and 2081754. Transmission 901/10 (4 gear). # 208XXXX. Engine and trans number are not identical (just by coincidence). Mine is 68 too and has original webers. |
