ceramic coating for exhaust???
Hello All,
I'm getting too much heat from my aftermarket exhaust/headers and think the best thing to do is to send them out to get a high quality ceramic coating put on.
Anyone recommend someone they trust to ceramic coat my headers???
1987 Porsche 911 Carrera Coupe
Old 06-14-2017, 02:37 PM
Why not just wrap them with that heat resident cloth. Be cheaper. You could see if that solves the heat problem.
Old 06-14-2017, 02:56 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Agree.
1981 911SC Targa
Old 06-14-2017, 03:07 PM
gtc gtc is offline
abides.
gtc's Avatar
There are ceramic coating shops all around. I'm sure there is someone local who can do it.
Graham
1984 Carrera Targa
Old 06-14-2017, 05:11 PM
Shaun @ Tru6's Avatar
Jet Hot is the standard for exhaust coatings. Two of our customers wanted aesthetics/correctness so we used Cerakote high heat for this muffler for a shop in OH and 65 220SE exhaust manifolds for one in CA.
Tru6 Restoration & Design
Old 06-14-2017, 05:47 PM
3 restos WIP = psycho
kenikh's Avatar
Finally, a correct looking gray!
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-14-2017, 05:58 PM
Eng-o-neer
Tremelune's Avatar
What do you mean you're "getting too much heat"? Too much heat for what, the motor?
Exhaust wraps tend to trap moisture and lead to corrosion. The only place I'd use it is on a standard motorcycle, because it looks cool while it traps moisture.
Old 06-14-2017, 06:18 PM
Navin Johnson
TimT's Avatar
I took these pics to post in another thread regarding "what headers are these or something...)
The one part of this header system is coated by Jet Hot.. the other by Swain Tech...
The Jet hot is a smooth fairly thin coating... Swain is grainy looks porous and is thick..
Both are good while they last, and both will fail at some point... a scratch, poor surface prep, application...I wont get into why portions of this exhaust system are coated by different manufacturers
'69 911 GT-5
'75 914 GT-3
and others
Old 06-14-2017, 06:28 PM
famoroso's Avatar
[QUOTE=Shaun @ Tru6;9626572]Jet Hot is the standard for exhaust coatings. Two of our customers wanted aesthetics/correctness so we used Cerakote high heat for this muffler for a shop in OH and 65 220SE exhaust manifolds for one in CA.
What would you suggest for correctness for a 1988 factory sausage muffler?
3.2 Carrera muffler reconditioning?
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 06-15-2017, 05:25 AM
As you probably know, these mufflers were just mild steel so rust is correct. The one posted by 997at looks good, a little on the light side and looks slightly green but that could just be the camera. I would do something a little darker and greyer for a Carrera but really it's about personal taste on what shade of grey you like and would work on your car. Or maybe even white if your car is Guards Red and you want to go with a white frame 93 Ducati 900SS look.
Old 06-15-2017, 07:18 AM
Cerakote offers more color selections than Jet Hot.
https://www.cerakoteguncoatings.com/finishes/SE-234/cerakote-color-chart-25-pk/?gclid=CjwKEAjw4IjKBRDr6p752cCUm3kSJAC-eqRtQESE25kE7aqTI0QetskzM_38Crb8e8b6HoQsm3cDZxoCIi Dw_wcB
No affiliation
Sherwood
Old 06-15-2017, 08:26 AM
E-85 sippin drunk
turbobrat930's Avatar
I did not coat my primary and secondary headers, because I did not want to take the chance of a piece flaking or getting knocked off, and F.O.D.'ing out my turbo. But, I did have Performance Coatings in Jonesboro, GA "perma chrome" ceramic coat my wastegate exhaust, as well as my exhaust behind the turbo. Here is a short video of what they look like.
if you did your whole header system, you will most definitely see a drop in temps...
idle from under car.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-15-2017, 09:33 AM
perfect... THANK YOU ALL!!!
I checked out Jet-Hot's website and am working on getting my headers in for a flat white ceramic coating. I was told that white is the best for heat protection.
As for using an exhaust wrap... the headers have heater boxes welded on them and I wouldn't be able to get the entire thing protected properly with a wrap. I also understand that wrapping it won't provide as good of a heat protection as ceramic coating.
It's about $500 to get them coated... should take less than 2 weeks.
Old 06-15-2017, 02:34 PM
Occasional User
Cook&Dunning's Avatar
Hi turbobrat - you really need to clean up that engine - it is a mess! Just kidding that thing is a piece of Art. Beautiful.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 06-15-2017, 04:36 PM
9elf's Avatar
I coated mine. Inside and out. If only to reduce the radiant heat somewhat and to stop corrosion.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 06-15-2017, 07:29 PM
Eng-o-neer
Tremelune's Avatar
Well this got interesting.
What's the cost difference between a stainless steel exhaust and one that has been ceramic coated inside and out? Comparable corrosion resistance?
I had assumed that the primary purpose of ceramic coating was corrosion resistance and cosmetics (for which I would assume stainless is superior)...Am I about to learn that coating these things has an appreciable effect on engine temperatures at speed?? 911 exhausts get better airflow than their oil coolers...
Old 06-16-2017, 06:47 AM
Too much heat for the oil lines and fuel lines. These Fabspeed race headers extend out past the engine and sit DIRECTLY below the rubber oil return line. In fact.. I had to get a wire tie just to pull the oil line off of the header as it is that close.
Old 06-16-2017, 08:16 AM
E-85 sippin drunk
Actually, you are only partially correct. Yes, it helps prevent mild steel from corrosion, and well as keeping it look good. But, it also does more.
On a S.S. header/exhaust, it really does not aid in corrosion resistance (especially, if they are 321), but does keep them looking nice.
But, there is a point you are missing on the heat reduction side of things. This may come into play more on a turbo setup, but none the less, it still applies here as well.
There are three things that aid in helping the exhaust system maximize the available HP ( or at least not hurt HP). They are:
-proper scavenging (equal length, well designed collector, tubing size matched for the engine its on)
- sound pressure (on a turbo car)
-and heat.
My point is, the more heat you can keep in the exhaust stream, instead of radiating it out, the faster, more efficiently the exhaust will flow. Remember, heat is energy.
And yes, it also keeps the engine area cooler, which helps in everything, including oil temps.
Old 06-16-2017, 08:20 AM
Speed Dog's Chauffeur
Dodge Man's Avatar
Look up the K Factors
Define too much heat? Oil temp? Headers run much cooler than heat exchangers. My buddy's steel headers do not have over heating problems and my SSIs do not either. What material is your exhaust system? Mild steel or SS? IMHO Pick you coating carefully because the K Factor varies widely. It is all about keeping the heat in the exhaust tubes and out the back. Best of Luck.
Old 06-16-2017, 08:38 AM
