El Duderino
tirwin's Avatar
Cam housing won't stop leaking oil
First of all, Happy Father's Day to all you crazy car dads!!!
I've got an oil leak I can't seem to fix. It's where the banjo connects to the bottom of the right cam cover. This isn't mine -- I just circled it in this pic from the Pelican catalog.
I've tried replacing the washers on both sides of the banjo. Same result. I think these are aluminum and the originals may have been copper. Could that make a difference?
What's the problem here? Is it possible I'm over-tightening?
Any suggestions on how to fix for good would be greatly appreciated.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-18-2017, 10:02 AM
72911's Avatar
The fitting that comes through the cam cover has an oring. If the cam covers have been off recently the oring may have been cut when re-assembling.
72 2.7 Driven!
Old 06-18-2017, 10:06 AM
El Duderino
tirwin's Avatar
Good thought. Is the o-ring on the inside of the cam cover?
Old 06-18-2017, 10:09 AM
72911's Avatar
Yes, the cam cover needs to be removed to change the oring.
72 2.7 Driven!
Old 06-18-2017, 10:13 AM
El Duderino
tirwin's Avatar
Excellent, thanks. I will check that. Just need to find a part # for the o-ring then.
Old 06-18-2017, 10:16 AM
El Duderino
tirwin's Avatar
Looks like this is the o-ring?
Part #: 999-701-690-40-M17
Old 06-18-2017, 10:30 AM
