LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
ROW '78 911 Targa
timmy2's Avatar
I知 installing the Refuze it version today on the harness I shared a photo of in your ID connectors thread. The original fuse panel was cracked and had seen some heat from bad connections in the past. Especially terminal 2. You can see the discoloration of the screws on 2 and 3. The original wire to terminal 2 was in terrible shape. All black and corroded.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-10-2017, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #401 (permalink)
I think that CR does not make a fuse panel specific to your car . Their fuse panel is very well done, but only suitable for some models.
Refuze does make fuse panels for most of the air cooled Porsches.
Old 11-10-2017, 10:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #402 (permalink)
CDD Autogear manufactures ReFuze panels for all 356, all 912 and all 911 Porches.
"Never be gnawed by the rats of remorse" Bill Brockett
CDD Autogear manufactures ReFuze ATO fuse panels to retrofit all 356, 912 and 911 Porsches up to and including 1989
Old 11-10-2017, 05:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #403 (permalink)
echecsqueen's Avatar
electrical journey continues
Refuse it it is then! Thanks all.
This morning Mike H. on 912bbs gave me a link for the 602 page service manual for the 912....so I sent it to my printer with a new set of laser cartridges and a ream of paper while I got to work on the car. Plan to put it in a binder - don't like having my laptop out when under the car.
Spent another full day cleaning, ID'ing and wrapping new wires in the Tesa harness tape. The tape is wonderful - not gooey at all. I am a little compulsive so labels were placed as each area is completed and marked on my wiring diagram.
Sometimes a girl uses a little too much acetone and loses her trace marks. Luckily we have nail polish in every color with three women in the house
I cleaned the molded connectors as per timmy 2's instructions and repaired/soldered the damaged wires. Not a fan of liquid electric tape, but prefer it over the conventional stuff when I can't shrink wrap. They clicked into place for the first time!
As soon as I finish this part, I will begin to refuse...
Biggest fix of the day....the main ground for the dash had such thick paint under and over it that I am amazed that anything worked at all! There was literally no bare metal. Very satisfying to scrape that off. and run all new ground lines.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 11-10-2017, 07:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #404 (permalink)
Originally Posted by timmy2 View Post
I’m installing the Refuze it version today on the harness I shared a photo of in your ID connectors thread. The original fuse panel was cracked and had seen some heat from bad connections in the past. Especially terminal 2. You can see the discoloration of the screws on 2 and 3. The original wire to terminal 2 was in terrible shape. All black and corroded.
How did you like it? I ordered mine tonight. More motivation to finish my wire clean up. If it goes well I may get one for my '88
Old 11-10-2017, 09:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #405 (permalink)
ROW '78 911 Targa
timmy2's Avatar
I have installed numerous ReFuze it panels on new harnesses.
They are a great replacement.
I’ll post up a photo tomorrow some time.
Dennis
Old 11-10-2017, 10:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #406 (permalink)
ROW '78 911 Targa
timmy2's Avatar
Picture as promised.
ReFuze It panel installed in place of the broken factory unit.
Still need to add the front harness wiring to it, but it sure looks good as far as fit, size and dimensions are concerned.
Dennis
Old 11-12-2017, 09:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #407 (permalink)
Looks nice Dennis! Mine is on its way. Did you use any solder? you seem to have fewer wires running under the panel than I do...I have a big mass that crosses under and want to minimize their bulk.
Old 11-12-2017, 09:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #408 (permalink)
Today I made my cow hide door pockets, finished installing the original Blau Frankfort X, the single speaker as well as the stealth head unit, amp, sub, and door speakers. I have decided to run the wires along my door straps for now so am making little cow hide pockets for the wires to travel in.
I finished cleaning up the under dash wiring, and repaired the damaged and missing wires at the ignition. The seats were difficult to reinstall with all of my soundproofing but finally got them back in.
Tomorrow after work I will finish the radio wiring in the trunk and harness tape everything after I give it a test.
Old 11-12-2017, 09:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #409 (permalink)
stereo
Old 11-12-2017, 09:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #410 (permalink)
ROW '78 911 Targa
timmy2's Avatar
As I noted, I still have all of the front wiring harness to connect to it.
It will bulk up considerably when I get to it.
No solder used, all terminations have ferrules crimped on the wire ends.
I壇 have added the front harness, but family stuff took precedence today.
(Good thing this isn稚 my real job!)
Dennis
Old 11-12-2017, 09:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #411 (permalink)
How does one go about getting wiring this clean?
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 11-13-2017, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #412 (permalink)
[QUOTE=mickey356;9813277
[/QUOTE]
That is what I want to know. I am working on it.
Old 11-13-2017, 11:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #413 (permalink)
Marilyn, if you can get it this clean I'll drive down to NOLA and you can do mine for me.
Always wanted to visit New Orleans.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 11-14-2017, 12:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #414 (permalink)
Well Mickey,
I would LOVE a visit from one of my Porsche fanatic brethren, but this wire cleaning, replacing and repairing is a labor of love. I only see myself doing this once. There seems to be a small army of evil sadistic POs that spray black undercoating on their entire trunk contents - wires, relay and all, and then sell their cars to OCD people like me that feel compelled to clean them off. What a sticky nasty mess!
On the bright side, it is very satisfying to see the trunk transforming one wire at a time
Old 11-14-2017, 06:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #415 (permalink)
Well Mickey,
FINE! I値l do it myself! Whatever!
Just keep posting with lots of pics and I値l copy your work.
Most of my wires look to be in decent shape so I値l do the best I can with what I have. Eventually, when I do get to where im ready for the down to the metal tub resto, I知 gonna be shooting for that clean look in the pic I posted, I HATE wires!
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 11-14-2017, 09:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #416 (permalink)
ROW '78 911 Targa
timmy2's Avatar
Post 85 starts to show Chris installing it all and explains where it came from...
Switzerland 1967 911S restoration
Dennis
Old 11-14-2017, 10:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #417 (permalink)
lateapex911's Avatar
I like wires, but i LOVE the woven cloth harness stuff. I can't figure how to use it without staring over, and I can't even describe it, but I've seen pictures someplace and it's ideal and cool for our cars. OK, I know this is fuel line but it's the look that I seem to recall seeing for wire loom fabric. Or, I'm imagining things!
Anyone got any info/thoughts?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-15-2017, 12:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #418 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by lateapex911 View Post
... I seem to recall seeing for wire loom fabric. Or, I'm imagining things!...
Fabric Woven Heat Shrink. I use Raychem. Some size are big enough to do oil line.
Here is a few links: https://www.google.ca/search?client=safari&rls=en&q=woven+fabric+heat+shrink&ie=UTF-8&oe=UTF-8&gfe_rd=cr&dcr=0&ei=_hcMWoXhCs-IhASl66DQBg
Who Will Live... Will See
Old 11-15-2017, 02:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #419 (permalink)
Timmy2, THANK YOU! Your work is amazing! And even though it's been said many times I'll say it again, your knowledge and expertise is unparalleled on this forum and I want to thank you for your patience and continuing contribution.
lateapex911, I meant, I HATE messy wires, nice neat wiring wrapped in cool stuff can actually add to the details that separate a car from the pack.
I remember seeing a pic one time of a VW bug where all the wires were routed perfectly. It was art!
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 11-15-2017, 09:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #420 (permalink)
