Danned
yes, spray the studs/nuts holding the cluster in with Kroil, etc. and tap on it - repeat 3x day for a few days
then see if the nuts will come off easily - do not break the stud off clean up the entire area - you will likely find hidden rust under the cluster clean the holes, cover with dum-dum |
Carl v S
![]() Nasty dirty pedal cluster before complete tear down, cleaning painting and reassembly. I recommend taking it out, apart, taking it somewhere and having it blasted and Powder-coated and then installing new bushings and re assembly. You’ll never have to go back and do it again. Sent from my iPad using Tapatalk |
The Queen's Outlaw
Done
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 Last edited by echecsqueen; 02-06-2021 at 10:22 AM.. |
Thread Tools | |
Rate This Thread | |
