LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
echecsqueen's Avatar
Thank you raw...
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 06-22-2017, 11:16 AM
Ok mr multimeter....i need help. Got first gauge out. Oil and fuel. Oil goes straight up on start fuel sits at empty. Cleaned it all i have my multimeyer ready. There are 2 brown (ground?) 2 blue and yellow 2 black with bulbs and one brown with silver stripes........what do i do to test? The black seem to be reading 24v.
Old 06-22-2017, 12:55 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Is that the oil level gauge you are referring to (the typical combo gauge with fuel level) - not oil pressure? Regardless, typically when a gauge pegs at the top of its scale, it means that there is power there by the sensor signal wire is not making contact with the sensor (is either disconnected, wire broken, or corrosion build up . . . or bad ground connection for sensor), so check out the wires on the oil tank level sender that is on the side of the oil tank (behind right rear wheel).
Fuel sitting at empty "might" mean it is not getting power. Can you take a pic of the back of the gauge and post it? Will be easier to give accurate advice (at least somewhat accurate) and not get confused by your cars conversion to the later style gauges.
You should not see 24v anywhere on the car unless you have two, 12v car batteries wired in series.
Old 06-22-2017, 01:29 PM
Originally Posted by Bob Kontak View Post
Yes. I have used the metal ones on my 81 which are a wee bit taller. Metal ones like to slide on a smooth concrete floor. The plastic compound ones have a rubber pad that bites.
Bob, you forgot to mention that you have to stack three of them B.A.B.s on top of each other in order for you to get under your 911!
Old 06-22-2017, 01:44 PM
The Mighty Pieholio
Bob Kontak's Avatar
My belly is not really a six pack. It's more of a one pack. I mean, if those ergonomic balls are considered a "pack".
Thanks for hurting my feelings after I promised to be nice here.
The ol' BAB will carry on.
You have a great day, Raw.
Thank you for your thoughtful opinion.
1981 911SC Targa
Old 06-22-2017, 02:55 PM
Am mailing you a 30 pack of Stones to make up for my insensitivity about your one-pack . . . or should I send 60?!?!?
Old 06-22-2017, 03:14 PM
The Mighty Pieholio
Bob Kontak's Avatar
Just saying in a kinder, gentler voice..........
I cherish the times when we fixed that van up and just cruised around.
You were a friend then.
1981 911SC Targa
Old 06-22-2017, 03:26 PM
What happened to the "Free Candy & Puppies" signage?!?!
PS - Queenie is going to be upset with the "wild boars"!
Old 06-22-2017, 03:29 PM
The Mighty Pieholio
Bob Kontak's Avatar
PS - Queenie is going be upset with the "wild boars"!
1981 911SC Targa
Old 06-22-2017, 03:30 PM
Discseven's Avatar
A high compliment from KinkyKarl - thanks, Bro!!!
Ya mann! Hope all's well with ya Ronski! Am luvin photo of you and Bobo doin the XmasTango! Great form
Queener... Pardon me while I mess with Ronski. BTW, nice to have you here. Adds a fine dimension.
Karl ~
Current: '80 Silver Targa w /'85 3.2
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver 930. '79 Black 930. '79 Anthracite 930.
Old 06-22-2017, 05:36 PM
KinkyKarlicious, Bob is an excellent, all-season Tango partner, as are you, my swampland friend - two of the best "swingers" on Pelican!
And agreed - most excellent to be graced with the Queen's presence, fa' sho'!!!
Old 06-22-2017, 05:56 PM
The Mighty Pieholio
Bob Kontak's Avatar
Queen: https://www.youtube.com/watch?v=3YxaaGgTQYM
Karl: https://www.youtube.com/watch?v=6fVE8kSM43I
Bob: https://www.youtube.com/watch?v=YQSB6VUzUU8
Ronnie: https://www.youtube.com/watch?v=_48JNlRIERw
1981 911SC Targa
Old 06-22-2017, 06:16 PM
LJ851's Avatar
Would a 912 have an oil level gauge? I don't think the four bangers are dry sump'd.
Old 06-22-2017, 06:59 PM
Ha! Great tuneage selection, Bobasaurous (ya' eff'in BAB!)!
Good gawd - I keep forgetting about the 912 wiff 914 engine scenario!
Queenie, my previous comment about the gauge pegging at the top of the range still applies, so check the connection at the oil pressure sending unit. It is near the crankcase breather on a VW Type IV engine (what you have) - breather is on centerline of case at the fan end.
Do you know what the sending sending unit looks like?
Old 06-22-2017, 07:10 PM
OK well I got impulsive and removed the gauge. Took it apart, cleaned all the connections and redid the ground connections. Take a peek....
One of the blades didn't have a wire to it so i hooked up a ground and tested it......
Old 06-22-2017, 08:29 PM
And guess what?!
It worked! The "oil" gauge works and so does the fuel.....
better lucky than good. This gave me confidence to tackle the next non functional one"
So I did the same thing. This time, since the one bulb that was working had a jump wire (I checked with the lucky lady multimeter) i attached a jump from the 3 o'clock bulb to the 6 and removed the dead wire from the one next to the speedo cable. Cleaned the nasty gook off of the face, and checked the gears that looked normal. put it back in. will have to wait tilll tomorrow to see if the speedo works, but at least the lights work!
Old 06-22-2017, 08:44 PM
OK didn't tackle this next one because this is what it looks like....egads, no idea here. A special treat from the PO. He had painted all of the wires black...yes solid black...really.
The tachometer from hell. Notice the missing bulbs and lots of extra unplugged wires...
Anyone want to take a gander at this one???
queen
Old 06-22-2017, 08:47 PM
I am embarrassed to say I have no idea what a crankcase breather or a sending unit is....let alone what they look like.
Old 06-22-2017, 08:50 PM
Excellent progress, Queenie!
And per the post #s93 and 94, can you confirm what exactly is being measured via the oil level gauge, since 914 engines are not dry sump and do not use a separate oil supply like 911s are/do (no oil tank, which is what that gauge measures the level of).
Is your engine somehow modified for this? I'm very curious about that . . .
OK I am silly.....that was 24 mV not volts. It was not a live wire until I turned on the lights and then it became 12V as expected. thanks
Old 06-22-2017, 08:52 PM
