Strange Idle Issue - Possible CIS problem?
Hello - Brand new Porsche owner here.
Background: I recently purchased a 1981 Porsche 911SC with 78,000 miles. It has decent documentation - 3rd owner - Ive driven the car roughly 300 miles Motor was out for a rebuild at 70,000 miles in 2005 (12 years ago) There were many things replaced (Long list) - but from the CIS main components the following were replaced: O2 sensor Fuel pump Rebuilt Fuel Distributor head remanufactured Warm up regulator (WUR Model 0438140090) Situation: I am having difficulty diagnosing a rough idle situation. The car will cold start with foot pedal half way to floor holding for 30 seconds or so to smooth out idle (a little rough to start) - but then the car runs phenomenal.. 900 revs at idle (dead straight) and can drive for hours. I have taken 4 long trips with one lasting 2 1/2 hours with no idling problems or performance issues.. However - Once I shut the vehicle off and try to restart - the car runs horrible. It will start with no problems - but will not idle. It will oscillate ("hunt" or "lope") up and down around 500 to 700 rpms and performance will suffer - I have little backfires or sputtering that happens upon acceleration. Its still drivable - as I drove it 30 minutes to get home after a car show this way - however it doesn't correct itself - it ran rough and idled rough the entire way. If I leave the car overnight - It will start and idle at the 900rpm range - running like the car I imagined.. BUT shut it down to fill up with gas - then it runs like crap.. Any suggestions to the components I should test or change? :confused: Im not sure where to start - and this issue severely diminishes the use of this car.. I have searched and read through many threads (so I am working on educating myself) - I ordered a CIS fuel pressure tester and I can use a multimeter. I also have the Bentley manual. The CIS system is all new to me - so I made need some step by step help in performing the tests.. |
don't you have another thread going.
2 threads aint cool. |
Reached out to forum here.. http://forums.pelicanparts.com/off-topic-discussions/960631-help-i-cannot-post-new-topic-tech-forum.html I totally agree - "Not Cool" |
| All times are GMT -8. The time now is 08:39 PM. |
