Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Low on power then it will light up
My situation is getting more frequent so now I need to look into it closer. When I start the 88 (100k miles on the clock) on a cold start after sitting for a day, 2 weeks or maybe longer, the car will start but struggles to idle. After about 2 minutes of me controlling the throttle so it will not die, it will idle fine. When starting to drive it, the car feels very low on power and is rough, as if it is down a cylinder or 2. after driving it for 5 or so minutes, it is as if you flip the light switch and it accelerates and drives as it should. any thoughts on where I should start to look? thanks in advance.
Charles
79 930 #632
88 911 Cab
74 TR6
88 CRX Si
Old 06-18-2017, 01:28 PM
Drive it more often. Italian tune up!!! sticky ICV?
Old 06-18-2017, 07:03 PM
76 911S Targa
How long between fuel fills? You may be running pretty old gas if you only drive it every couple of weeks. If you do not drive it often try to fill up with non-ethanol premium to avoid water in the fuel.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Trombone Oil Cooler, Turbo Tie Rods.
Old 06-18-2017, 08:33 PM
Sounds like the ICV. Do some searches and you will see how to test it, etc. i had similar issues a while back and that was the culprit.
'87 Carrera (3.4L)
'07 Boxter
Old 06-18-2017, 11:47 PM
T77911S's Avatar
temp sensor issue or related.
maybe a solder joint on the DME
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 06-19-2017, 02:56 AM
Like this^
Cylinder head temp sensor.
Old 06-19-2017, 07:31 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
