cliyde's Avatar
+1 on Steve T. Very knowledgeable and helpful with my 3.6 transplant. He makes/fabricates lots of conversion gear. He should be able to get you going and keep you on the road once there!
Cheers!
- '88 911 (3.6 Transplant, Big Reds, Coilovers)
- '12 Audi B8 S4 (6MT)
- SOLD! '84 911 3.2 Turbo Targa
- SOLD! '85 928S 5sp with LSD
Old 06-22-2017, 04:40 AM
froggert's Avatar
Originally Posted by Tremelune View Post
Having just a single fender cooler up front will be dicey, though you might be able to get away with it depending on where/how you drive. My 3.6 car has a center-mounted oil cooler that I intend to eliminate, and I'm hoping that installing monster fans on the right fender cooler will be enough to compensate (it currently has none). I'm much more concerned about overheating at idle in traffic than I am with overheating at wide open throttle, but my car never sees a track anymore.
My car has a 915 and a '95 3.6 and they knocked a bit of extra space in the interior to make room above it. I'm not sure how the G50 and varioram plumbing will affect that, but another thing to be aware of.
I ran the stock passenger side Carrera oil cooler with fan for a while and it was fine 95% of the time on the street. Oil temps would creep up in heavy traffic when it was 85+ degrees outside.
The varioram intake fits in my '87, but it's toight like a toiger. Swapping out the throttle cable required a friend with pipe cleaner type arms.
Old 06-22-2017, 05:59 AM
arrivederci's Avatar
+1 on Steve T as well. I bought the kit from him and then subbed in a couple of things I wanted done differently. He was also super helpful troubleshooting some issues I was having with wiring. I shipped him my ECU and he even tested it in one of his cars to confirm that my ECU was good. Great post-sales support.
- '72 911T
- '81 911SC Euro
Old 06-22-2017, 06:01 AM
porsher
aston@ultrasw.c's Avatar
Patrick Motorsports has an amazing array of parts on their website but they are seriously expensive. I do buy parts from them but it is always my last resort.
OTOH Steve at Instant G is very helpful and his prices seem fair to me.
86 911 Carrera, with a few 993 bits in the boiler room.
Old 06-22-2017, 11:11 AM
Eng-o-neer
Tremelune's Avatar
Pricing is kinda hard to sort out, but:
3.6 Engine Conversions – Instant-G
Are they still selling 3.6s that they've gone through for $15k? That seems...unsustainable.
Old 06-22-2017, 11:40 AM
Originally Posted by safe View Post
OK, the 87 flywheel could be reused, didn't think about that.
The '87 G50 flywheel will not work (sensor teeth are for a 3.2 motronic not a 3.6)
However, an '89 964C4 3.6 used a standard, non dual mass flywheel.
http://www.pelicanparts.com/More_Info/96410223900.htm?pn=964-102-239-00-OEM
On my '89 964 3.6 transplant to an '80SC, I used it's 240mm flywheel with the 915 by machining it to accept a 915 225mm pressure plate. Has worked great since I did the swap in 1992. It was my only path as there were no "conversion" flywheels or other parts back then!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-22-2017, 11:47 AM
914-6Werkshop
3.6 Engine Conversions Instant-G
Just call him.
A part isn't purchased until paid
Old 06-27-2017, 09:46 AM
Eng-o-neer
Tremelune's Avatar
Originally Posted by mepstein View Post
Just call him.
You are drastically underestimating the lengths I will go to avoid a phone call...
Old 06-27-2017, 09:52 AM
3rd_gear_Ted's Avatar
2 years ago price was $12.5K.
An iconic air cooled Metzger motor that is bulletproof, glad I got one
1980 911SC
Fiberglass Turbo Flares F&R with a 3.6L conversion
869#
AKA "Gemma"
Old 06-27-2017, 09:53 AM
Administrator
Jack Olsen's Avatar
It's good to see all this satisfaction with Timmins. I've already noted that I'm a happy customer from way back (I think I was the first to use his kit for a swap on the west coast).
One thing Patrick did solve is the issue of oil pressure readings doubled when the 964/993 pressure sender is paired with the earlier gauges. The older senders have 10-184 ohms of resistance cover a range of 0-150 psi, while the newer senders spread the same 10-184 ohms over 0-75 psi. Patrick found an adapter that will let you screw an older 0-150 psi sender (M10) into the newer engines' M18 hole.
I mention it because there are a cluster of 3.6 swappers here.
VDO probably makes a 10-184 ohm gauge over 0-150 psi with an M18 fitting -- maybe one of you found it?
Old 06-27-2017, 02:12 PM
jamesjedi's Avatar
Perhaps I am incorrect, was it not Hans Mezger? I think Metzger means "butcher". I only know this because I looked it up.
Old 06-27-2017, 03:24 PM
question
I have the 1986 3.2 with new B&B SSI
Can I use my SSI B&B header on 3.6L conversion?
My SSI is a thin Flange header
Old 11-02-2017, 11:50 AM
porsher
Originally Posted by frankoporsche View Post
question
You can.
You will need to change the mounting stud position on one side, RH IIRC - which probably means it's the LH
Anyway, the 3.6 has 4 threaded holes per port for 2 studs.
Old 11-02-2017, 11:59 AM
Originally Posted by aston@ultrasw.c View Post
You can.
Great ..thank you
Old 11-02-2017, 12:24 PM
safe's Avatar
You can.
Depends on if its a 964 or 993, only 993 flanges are different.
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI
Old 11-02-2017, 12:27 PM
Bill Verburg's Avatar
question
Depends on what the primary pipe sizes are. You will want at least 1 5/8" OD and preferably 1 3/4" for a 3.6. 1 1/2" will strangle the motor.
964 heads have a stud arrangement identical to earlier heads, you can use either thin or thick flange it's just a matter of either changing the studs or having extra length.
Here's a 3.2 exhaust port
964 studs arrangement is the same as 3.2
993 has both the early and late pattern just place the studs according to need
either a 964 or 993 can use the bigger B&B headers seen here w/ 964 heat pipe
Bill Verburg
Old 11-02-2017, 01:46 PM
Hello Bill
yes my header at least 1.5/8 OD but on instruction paper said 1 3/4 OD with 3 inch. OD exhaust
Thanks you
Old 11-02-2017, 08:14 PM
Hello Bill
Thanks you
B&B come in either 1 5/8 or 1 3/4, so it appears that you have the bigger size, that's good.
The biggest issue will be the oil line, the B&B will want as much vertical clearance as can be provided, a feed line that bends up is very desireable
Even then the rubber S hose is close to the header so some insulation is also desirable
Bill Verburg
Old 11-03-2017, 05:38 AM
question
looking to buy 3.6L for my 1986 Carrera...do I need to make sure what year or model 3.6L for my car?
Or get the complete conversion and the motor as one package deal from instant-G
Old 11-04-2017, 05:01 PM
Meanwhile:
The external -044 Bosch fuel pump works well.
I did an end to end replacement of the fuel lines with new metric stainless through the tunnel.
The stock 964 fuel filter works well
Route your oil tank breather hose into a puke tank up in the left rear wheel well to avoid oil tank fume deposits on engine
1980 911SC
869#
AKA "Gemma"
Old 11-04-2017, 06:00 PM
