attaching 930 steering wheel to hub
Just installing the 930 S wheel. Everything has come off and gone on fine. My question is how is the wheel attached to the hub?
There are three bolts on the wheel that line up with three threaded holes in the hub but the holes are much too large. The bolts go right through them. Should I be attaching with nuts on the back of the hub? If so, why are the holes threaded and wouldn't the nuts be included with the the hub or the wheel? Thanks in advance for your assistance.
Jeff '04 Cayenne S Hauler '98 993 Cab '74 Euro Carrera - SOLD '91 944S2 Track Car |
Sounds like you have the wrong hub! The three screws do screw directly into the hub if you have the correct hub. Do a search and you will find a ton of information on the install. Good luck
Matthew |
