-   -   Can someone tell me if this oil line can be rebuilt (http://forums.pelicanparts.com/porsche-911-technical-forum/961084-can-someone-tell-me-if-oil-line-can-rebuilt.html)
ds650 06-22-2017 04:12 PM
I have a 1968 2.0L engine. My understanding is that the OEM line has been replaced with a hose. I want to rebuild this oil line that goes under the transmission and connects to the oil tank. The OEM part number is 90110733112. Where can I buy the hose and fittings. This looks like a pretty easy job.
Item 18 on the diagram.
http://forums.pelicanparts.com/uploa...1498172818.jpg
Discseven 06-22-2017 05:19 PM
DS... Hydraulic place would have end-fittings and hose. Am not familiar with that connection between the hose end-fitting and hard line. I'd bring entire length and tell hydraulic place to solve puzzle. Need oil & high temp hose as opposed to any hose.
bazar01 06-22-2017 05:34 PM
You can bring all of them to a local hydraulic shop so they can see it. Most likely, they will only rebuild the rubber hose part and crimped fitting The metal tubing and compression fitting is reusable by design.
zippy_gg 06-22-2017 05:40 PM
Try Elephant Racing
The page specifies model year 72 and up, but you can call them.
turbo owner 06-22-2017 07:11 PM
Try Len Cummings aka boxterGT here on pelican. He's your best bet, all the hydraulic shops I visited when in need of repairs just had stupid looks on their faces when I told them the lines were from a Porsche.
ds650 06-22-2017 09:45 PM
I went to three hydraulic hose shops and they all where clueless. How can I get a hold of Len Cummings aka boxterGT? Can I send him a PM?
ds650 06-22-2017 09:48 PM
Thanks for the info zippy_gg. I'll give them a call in the morning.
proporsche 06-22-2017 11:54 PM
I have been using for most of my Porsche live these guys ...excellent work
Orme Brothers Inc. Performance Hose and Fittings
Ivan
turbo owner 06-23-2017 12:14 AM
[/http://www.autosportengineering.com/
john walker's workshop 06-23-2017 06:26 AM
All you need is the exact size hose and them it just screws together. The exact size metric hose is the issue.
72911 06-23-2017 07:20 AM
I've been dealing with Len Cummings for about two months now and he is not your best bet. Parts Klassic has a custom metric hose service.
KTL 06-23-2017 07:45 AM
Belmetric has high quality OEM-like Cohline hose
https://www.belmetric.com/metric-hoses-c-14.html
JimmyT 06-23-2017 08:35 AM
Your oil lines have reusable aluminum fittings made by TechnoChemie (TCh). They can be rebuilt. The hose is DN16 hose (18mmID x 25,5 OD) made by Cohline. I only make the larger, DN20 hose (22mmID x 30.5mm OD) fittings used in '70-'71, but you can contact Brad Davis at HBD Products & he can set you up with both the small fittings and the hose that you need.
Trackrash 06-23-2017 09:28 AM
I just used AN-16 stainless braided. Older cars may need -12 hose.
http://forums.pelicanparts.com/uploa...1498235273.jpg
http://forums.pelicanparts.com/uploa...1498235307.jpg
ds650 06-23-2017 12:03 PM
Thanks for all of your help !!! I found all the parts needed at parts Klassik I will post a picture of the whole assembly when I get the parts next week. Have a great weekend.http://forums.pelicanparts.com/uploa...1498244525.jpg
ds650 06-23-2017 12:39 PM
I did look into the AN-16 and AN-12 stainless braided lines. The ID and OD wouldn't work with my parts.
JimmyT 06-25-2017 07:31 AM
http://forums.pelicanparts.com/uploa...1498401026.jpg
Trackrash 06-25-2017 09:03 AM
FWIW, I used AN 12 to replace the hose from the engine to the tank on my '71. Had the OE hose wear through. No problems for decades with the AN stainless.
Perhaps the '68 is a different size.
http://forums.pelicanparts.com/uploa...1498406470.jpg
http://forums.pelicanparts.com/uploa...1498406610.jpg
ds650 06-28-2017 11:17 AM
Thanks again for everyone's help. I was able to fit a new hose end to my existing line.:):)
http://forums.pelicanparts.com/uploa...1498673729.jpg
