-   -   part number help....engine/trans mounts (http://forums.pelicanparts.com/porsche-911-technical-forum/96114-part-number-help-engine-trans-mounts.html)
bell 01-28-2003 06:56 PM
i'm putting an order from our host together and need some help.
from reading jack olsens posts and many others (from an insight from roninlb), but need to know which part numbers/mounts to use and which ones where.
i know it's going to be "rough", but it IS a porsche and that's what i want :D
bell 01-28-2003 07:30 PM
also how can i tell which axles i have? they switched during 85' (my year) from 100mm to 108mm. is the only way to check this to measure? and what part of the axle do i want to measure.....the main shaft?
thanks again guys
KTL 01-28-2003 08:40 PM
Bell,
You can tell if your axles are the early or late model by looking at the outer end of the axle. The part of the axle at the trailing arm. If the CV joint is bolted to the stub axle, you have the early axles. If there are no bolts near the CV boot, you have the later axles.
This picture shows the early axle setup. See the bolts near the CV boot?
http://forums.pelicanparts.com/uploads/surfrs2.JPG
For your 85 i'd go with the Club Sport/Cabrio engine mount. It's a little firmer than the stock Coupe/Targa mount. It's still rubber construction, but just a little higher durometer material i'm sure. Plus it's cheaper!!! You need part # C-375-403-07 from Pelican
Engine/Trans. mounts
You'll need 4 of them to replace all four mounts. Meaning, the engine bay mounts and trans. cross member mounts are EXACTLY the same part.
If you're thinking about the solid mounts, I have no experience with them.
bell 01-28-2003 10:06 PM
now i understand the difference in the axles :)
once we figure out the mounts i'll be all set.
