Sound When Turning While Clutch Depressed
Hi all-- I have an odd question that I'll throw out here to see if anyone else have run into this.
Every now and then, I find myself taking a low speed turn with the clutch depressed (a bit too slow for second gear, no downshifting into first...). It's usually when I'm pulling into a residential neighborhood or navigating a parking lot. When I do this, I hear a rhythmic sound during the turn. I wish I could articulate what the sound sounds like, but it's hard to put into words. Nothing scary like a screech, scrap, or grinding, but more like a series of clunking while i complete the turn. The sound isn't very pronounced. I am 95% sure that this sound doesn't occur when turning while the clutch is engaged (in gear).
Any initial thoughts? I can try to record the sound next time, but I'm not sure if my equipment can capture the sound.
1982 W123 300D
2000 986 S
Old 06-05-2017, 03:09 PM
crustychief's Avatar
CV joint? Check the CV boots for damage.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 06-05-2017, 03:41 PM
Damn good thought.
Old 06-05-2017, 03:55 PM
T77911S's Avatar
CV joint as said.
you should hear it going straight. suspension movement can make the noise worse.
its not like a front wheel drive car.
second would be a wheel bearing but those you should also hear all the time unless the turn is loading the bad bearing. try left and right turns.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-06-2017, 04:48 AM
Drisump's Avatar
When in gear, there would be more motor noise and likely a less acute angle of corner. (Possibly less noise from a CV or tranaxle issue). Cheers
Old 06-06-2017, 06:33 AM
For posterity, turns out noise is normal LSD noise. Low speed turns are often tight-angled turns, which causes mechanical noice from my LSD (says wrench).
1982 W123 300D
2000 986 S
Old 06-25-2017, 03:53 PM
Earthling
Brian Cameron's Avatar
Do you hear it only when turning? Or any time you depress the clutch pedal? If the latter, likely the throw-out bearing.
Edit: oops, should have read to the end.
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 06-25-2017, 06:48 PM
