Bad O2 sensor is a common failure mode. From this picture it looks like yours isn't plugged into the bung?
FWIW, a properly running 3.2 should easily pass California smog which is at least as tough as Colorado..
Bob F. 1984 Carrera Factory Turbo-Look Last edited by rfloz; 06-28-2017 at 09:08 AM.. |
Eng-o-neer
Beauty
I am a purist sir and that is a sweet ride
![]() Welcome!
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Welcome! Car looks good. Hope you can enjoy it soon.
That pic was after the cat was just installed so the O2 sensor was not plugged in yet. The sensor was tested and is good however the box that it connects to that piggy backs on the DME (it's a RoW car) does not seem to be doing anything with the signal. Spoke with Steve Wong and may have to have the DME circuit board updated to US spec. The Air Care Colorado counties here have emission requirements as stringent as CA.
__________________ 1985 RoW 911 Cabriolet |
Bob F. 1984 Carrera Factory Turbo-Look |
