-   -   Can you swap transmission midcases without reshimming? (http://forums.pelicanparts.com/porsche-911-technical-forum/961517-can-you-swap-transmission-midcases-without-reshimming.html)
Jeffreypang911 06-27-2017 06:35 AM
As the title says. Can you swap 915 midcases without the need to reshim anything? Bolt on and go?
Thanks!
Daugaard 06-27-2017 06:58 AM
915 Yes you can.
901 no.
Jeffreypang911 06-27-2017 07:09 AM
Thank you!
Realized the trans I just purchased has a few ribs broken on the outside. Not a big deal but my OCD says to swap over the old case to the new one. Also a good opportunity to check everything over too.
Matt Monson 06-27-2017 08:03 AM
Just don't unbolt the bearing plate and you're fine.
