Help With Tank in Driver Side Wheel Well
Can anyone tell me what this tank is? It sits behind the bumper in the drivers side wheel well. I'm pretty sure that it's the tank for the high pressure cleaner for the headlights.
When I make a hard right turn the tire rubs on the tube to the tank, so I need to correct it. I just bout the car - 88 Targa. Not sure if this is a common problem. Thanks.
Old 06-29-2017, 02:22 PM
It is windshield washer fluid. You can jack up the front, remove the wheel to gain access to it. There is that fastener on the top that you can see behind the small horizontal hose if the tank has moved. You can fasten the hose out of the way once the wheel is removed. That hose goes to teh fill port in the gas capp area. Are you running larger than stock wheel diameters by any chance?
Old 06-29-2017, 02:29 PM
Here is what it looks like with everything removed in that area:
Old 06-29-2017, 02:33 PM
Thanks. I am running stock wheels and tires. The hose seems tight so I will remove the wheel and try to fasten it. There are some other hoses back there too. I'll get a better look once I remove the wheel.
There is another tank in front of that one which does headlight washers I think. I removed all that for simplicity.
Old 06-29-2017, 02:35 PM
That may be the source of your issue and that of many others.
Are you talking about a low speed, full lock lefty? Have you changed wheel/tire set up?
1987 Marine Blue 930
1982 911SC
White Plains, NY
Old 06-29-2017, 02:37 PM
Stock wheel and tire size. It rubs when I lock out full to the right.
Old 06-29-2017, 02:41 PM
It happens, need to realign and tighten up bolts. Its a pain in the ass with the car on the ground.
Old 06-29-2017, 03:02 PM
Immature Member
dentist90's Avatar
I think you may have removed the tank to collect fuel vapours (expansion tank). There is no separate container for the headlight washer, just a separate pump built into the reservoir. If your car reeks of gas in the morning this would be the cause.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-30-2017, 09:04 AM
Diss Member
Quicksilver's Avatar
I've run 27" diameter off road tires on my car before and they didn't rub the tank. I did have to move the fender extension (behind the bellows) forward about 3/16ths forward.
Rubbing won't happen unless the tank is out of place.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-30-2017, 09:32 AM
You are correct it is part of the fuel expansion system. I have no fuel smell. That tank is outta here. Perhaps this is another of those systems mandated by government that further added weight and complexity to these cars. More info here if anyone is interested:
Fuel expansion tank replacement question
Old 07-01-2017, 10:46 AM
