Speedo off... maybe?
Hello,
At 3000rpm in 5th gear my speedo runs at 75mph. Is it correct? It just seems as if the car runs slower then the indicated speed. I am running with 225x45 / 245x45-16. The rim width is 7 in front and 9 in the rear. Would there be a website to give this information just by entering in some numbers. Calspeed 1985 911 Carrera Cabriolet |
Guest
Posts: n/a
I've read magazine tests of SC's which give 22 or 23mph per 1000rpm in 5th gear. Carreras might have a slightly higher 5th gear ratio though- which would mean your indicated speed is pretty close. I think most speedos on any car run a few mph fast.
BTDT.. try a portable GPS or follow someone on a level straight with a new car in cruse control.. I had to reset mine.. why not go to one of the speedo repair places that has a speed dyno.....Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
a G50 Carrera will run about 70mph at 3000. The shorter tires 245 45 will spin faster for a given speed, so will cause a low reading not high, but the difference in height is so small that the difference is negligible at normal speeds. A 915 tranny may be different, but you could be running 5mph fast.
There should be a chart in your owners manual that will give you speed vs rpm.
Chuck 1987 911 Targa 1962 C182 "Dirt is permanent. You can move it around, but you can never destroy it." |
