-   -   HELP!! 911 SC hesitating/stalling and refusing to restart until cooled (http://forums.pelicanparts.com/porsche-911-technical-forum/961921-help-911-sc-hesitating-stalling-refusing-restart-until-cooled.html)
Vereeken 07-08-2017 07:35 AM
Originally Posted by Kris G (Post 9654251)
1. The Brazillian Coil was checked and was a dud - so Bosch Australia will be hearing from me.
Whah so Bosch silver coil has a 100% failure rate. At least they got that right.
Don't bother. Bosch could not care less.
What you could do is the following:
Take the silver coil. Go to a Bosch office near you. Throw it at the first employee that wears a Bosch badge. Success guarantueed. Post on Youtube.
Kris G 07-08-2017 08:04 AM
Originally Posted by boyt911sc (Post 9654359)
Kris,
This would a good time to get your control fuel pressure data. BTW, you have not shared with us the Bosch ID number of the WUR. From a cold engine, measure your cold control fuel pressure until the warm control pressure stabilized. The duration of the test should last about 5 mins. plus. Stop the test once the WCP is steady and not changing. Keep us posted.
Tony
Tony my apologies - I did promise you that. I'll burrow into the engine bay and get you the serial number tomorrow.
I assume the number I am looking for is the stamped three digit number starting in 0?
Kris G 07-08-2017 11:33 PM
Tony the serial number on the WUR is 0438140 089
Jonny H 07-08-2017 11:43 PM
Reason for failure is internal voids (bubbles) in the epoxy insulation that they are filled with. If the void happens to coincide with the coil wire then it will arc internally and destroy itself (and possibly the CDI box as well).
(And yes, we have cut one in half to discover this!)
boyt911sc 07-09-2017 07:03 AM
Wur..........
Originally Posted by Kris G (Post 9646991)
Mine is a 78SC US/Can Spec car.
I'll get the ID number off the WUR. I think I will be buying a CIS pressure gauge kit as well.
Kris,
Your engine should have a WUR-045. WUR-089 is for a ROW/Euro spec. They are not the same but would work.
Tony
Kris G 07-12-2017 01:48 AM
Jonny are the coils you sell compatible with the old CDI box or your CDI box only?
I have heard good things about them, but those who have one are running it off your product.
Cheers, Kris
Kris G 07-12-2017 01:52 AM
Originally Posted by boyt911sc (Post 9655408)
Kris,
Tony
I can say it is plumbed into the system properly.
How many bars should I be looking at with the cold control pressure test?
Cheers, Kris
Vereeken 07-12-2017 01:56 AM
Cheers, Kris
Good question. I also want to know.
SkiVT 07-12-2017 03:10 AM
089 WUR specs
http://forums.pelicanparts.com/uploa...1499854218.jpg
Kris G 04-15-2018 04:48 AM
So gentlemen I know it has been some time, but I have finally been back in Australia and able to take my car to my preferred mechanic. The issue was quickly resolved - The CDI box was the culprit. Annoyingly as I sent the box the Pelican Parts to be fixed, it evidently had a dry joint in one of the soldered wires which either occurred during the repair or was missed. Like most I dismissed the idea that a rebuilt component could still have a fault. Lesson learnt This issue would only surface once engine bay heat soak in Australian temperature conditions set in. To confirm the fuel injection system has no vacuum leaks. The remedy for the situation was to put an MSD ignition system in. Gentlemen thank you for your input into this issue. It really does demonstrate the strength of forums such as this.
