How do you remove chalky film on new rubber?
I just purchased a new rear bumper rubber from our host and the new one is chalky. How do you remove the chalky film?
Old 04-13-2018, 04:02 PM
Fleming's Avatar
It's talc. Dip it in Hot water.
Always start with the mildest chemical and if it doesn't work move to the next.
Water
Hot water
Soap and water
Citrus Cleaner
Prep-sol / Prep-all (wax and grease remover)
Paint thinner
etc.
Let us know what works for you.
Old 04-13-2018, 06:06 PM
Undocumented User
McLaren-TAG's Avatar
I've used WD-40 with good results.
Old 04-13-2018, 07:10 PM
911 Mania
The rubber is blooming. Read attached.
http://www.hitechseals.com/includes/pdf/Rubber_bloom.pdf
"When the debate is lost, slander becomes the tool of the losers." Socrates
Old 04-13-2018, 07:14 PM
Thanks for the replies! Blooming was the issue.
I first tried cleaning with soap and water with so so results. Then moved on to WD-40. This seamed to clean off the residue, but left the rubber dull. Tried mineral oil and that helped a lot. Then I tried Mother’s Back to Black and this helped a little more. Finished it off with Gummi Pflege and here are the results...
Old 04-14-2018, 05:50 AM
WD40 and other petroleum based chemicals should be kept off rubber as it deteriorates rubber. I use silicone spray on cleaned rubber parts to make them look good and offer some measure of protection. Keep silicone out of the engine compartment, though, as it can kill sensors (O2).
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-14-2018, 06:36 AM
TheSt|G's Avatar
Forever Black is a far superior product to Back to Black. Permanent fix rather than a temporary shine.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 04-14-2018, 06:46 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Get some of those Mr Clean Erasers at the grocery store. They are perfect for knocking off the white stuff.
I did it on my smiley with extremely good results.
Use the "black" of your choice and I do recall Forever Black is superior.
1981 911SC Targa
Old 04-14-2018, 09:26 AM
(man/dude)
Jonny042's Avatar
+ 1 on the magic erasers, they are really handy for certain things.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-14-2018, 03:31 PM
cycling has-been
bkreigsr's Avatar
Glycerin from the drug store.
Bill K
Old 04-15-2018, 06:03 AM
(man/dude)
Jonny042's Avatar
Bill K
Also great as lube when installing windows.
Old 04-15-2018, 06:50 AM
