Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Ok, I have owned floaters for quite a while now and have had trouble with imbalance/brake vibration a few times.
In every case (so far) it turned out to be pad build up on the rotor, perhaps caused by the crossdrilling peeling off more of the pad than a conventional rotor? Who knows.
But in all cases what it took was a series of very heavy braking/acceleration sequences to burn the rotors clean and then all was well for a while. Vibration went away/was greatly reduced.
Just sayin' this might be the issue...
Dennis
Old 07-05-2017, 05:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Just so everybody is on the same page here, those rotors and hats pictured are not the original 930 parts. Those look like they are VCI rotors which use their own hats and I believe a Wilwood UL (UltraLight) or Coleman rotor. People here on Pelican in the past have experienced problems with those rotors warping. Not pad material buildup warping. Actual rotor warpage.
930 Brake Upgrade 911 - Carrera - 914 - 914/6
Kevin L
'79 911SC widebody conversion
'86 Carrera
Past: '87 Carrera "The Unicorn"
Old 07-05-2017, 06:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
FWIW,....
I've not had any successes with Coleman 930 rotors over the years and I've found them to have as much as .011" runout, right out of the box.
Once in service, it gets much worse and there isn't sufficient rotor mass to true them up in brake lathe without compromising their thermal dissipation capacity.
Having tried that, they warped again (even faster).
We will not use Coleman rotors in these sizes due that reason. You get what you pay for.
Naturally, JMHO.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-05-2017, 09:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
If I scrap my disks, what setup, solid or floating, and manufacture would you advise?
Thanks!
Arild
Old 07-05-2017, 10:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
safe's Avatar
I have floating VCI hats with stock 930 rotors, they have been really good. The do make a lot of noise... If street driving is the majority I would choose non-floating
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI
Old 07-05-2017, 10:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
jm993rs's Avatar
Very good thread !!!
Thanks for share
Old 07-06-2017, 02:42 PM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
This should help.
https://youtu.be/eTECIPwSG-U
Old 07-06-2017, 06:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
With the original Porsche 930 hats ... if I recall correctly, you install them with the bevel outward and they are either floating or not floating and you can install the with the bevel inward the you will get the opposite effect. Can't remember exactly which way is floating but I think it is listed in the Porsche Work Shop Manual.
Rahl
Old 07-06-2017, 08:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
douglas bray's Avatar
Holy Cow Bill used my picture in his post!!!! What is the world coming to. I'll admit that is an honor. My 930 brakes are flawless and scare the ship out of my friends that ride along. I can go deeeeeeeep into corners than apply the jawzz of life to my silly little cab.
Got my rotors off p a r t s g e e k . c o m for half the price seen elsewhere. Well, go check out my thread. LOL.
Old 07-06-2017, 09:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
I think Clint is now just reselling the Coleman T-locks. I'm still all butthurt you guys wouldn't tell me about Coleman. Had to search the dark underbelly of the interwebs to find them stupid things.
Old 07-06-2017, 09:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #30 (permalink)
Not sure I did a thread here on raising my spindles 26mm and de-cambering them by 1 on a milling machine I got off Craigslist. Used parts from Rebel Racing and had a customer do the final welds. Love Clint. Highly recommended.
And ya, the pawn shop unloads all it's Snap On on me...
Old 07-06-2017, 09:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #31 (permalink)
Crap....where is the toolbox picture. About 35 sets of SO. Built the box myself right where it sits.
Old 07-06-2017, 09:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #32 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Thanks!
Go to p a r t s g e e k . c o m and enter 1978 for year, Porsche for maker, and 930 for model. Select the Zimmermann rotors. I've got Sebro in the back from them. Was literally half price and the same exact parts. Sorry, but the deals are out there.
Then go to Rebel and get the hats and Tlocks. The rotors and hats will have 12 slots in each so you will need 24 Tlocks. If you go to Coleman you will need to buy 3 of their 8 packs.
EDIT: I see that my other source has raised their price to the level Pelican has them....so go with Pelican. I've got Sebro on the back.
Old 07-06-2017, 09:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #33 (permalink)
I have done as told, parts are ordered from Rebel and Pelican, except I went for the Sebro disks, they are below 1/3 of the price compared to Zimmerman. The car is mostly used for street driving, my be trackdays, no racing, the car is below 1000kg, I will never manage to use the brakes to the limit.
Arild
Old 07-16-2017, 02:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #34 (permalink)
Sebro is the way to go then. Same same. I don't know what was up with pricing. I even noticed some vendors had lefts but no rights or visa versa.
At this point the only thing I'd do is swap in more aggressive rear pads on my car. I can lock up the fronts long before the backs.
Old 07-16-2017, 01:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #35 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Hey now. I pointed you to them directly. Give credit where credit is due?
Cleaning/Rebuilding 930 Calipers....
Kevin L
'86 Carrera
Old 07-17-2017, 12:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #36 (permalink)
Rebel don't respond either on mails or on the order, are they up running?
Arild
Old 07-18-2017, 09:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #37 (permalink)
safe's Avatar
Search is your friend.... Go somewhere else.
Magnus
Old 07-18-2017, 09:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #38 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
KTL KTL is offline
Schleprock
KTL's Avatar
Still in business making stuff. Their communication is slooooooow sometimes
I ordered some sway bar square nuts and some brake flex lines a few weeks ago and I'm still unaware if and when the order will ship
Kevin L
'86 Carrera
Old 07-18-2017, 09:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #39 (permalink)
I had to make a reorder, I got reply from Rebel, their setups were for fixed rotors only. I have ordered, from VCI, floating hardware used with Porsche original rotors.
Arild
Old 07-24-2017, 10:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #40 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
