My other ride is a C-130J
Cam Line Oil Restrictors
I've done a little searching here about the Cam Oil Line Restrictors (sold here by our host)
1978 Porsche 930 Turbo Coupe - Camshafts & Timing Chains - Page 2 and have a question for the brain trust. My 1983 SC motor with 140,000 miles runs as a well as you would expect a 35 year old motor to run. Drips very little Oil, been using Shell Rotella for 5 years now. After 1000 miles I need to add 1 quart of oil. Cold on start up (idle 900 rpm) oil pressure gauge reads 3.5 bars. When warmed up (idle 1000 rpm) oil pressure reads a hair above zero but for every 1000 rpm I get about 1 bar (2000 rpm= 2 bar, 3000 rpm= 3 bar, 4000 rpm= 3.5 bar) My Question: Do you guys recommend I install the cam Oil flow Restrictors to punch up the warm idle oil pressure? Thanks
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
I did it on my 82 SC and it increased the idle pressure by almost 1 bar.
This has been discussed a number of time on the site. Do a search. Dieter's of San Diego did some testing on this mod years ago and I think it appeared in the San Diego Windblown Witness. It's on their website: 911 Camshaft Oiling Update. This mod is also being discussed right now in this thread 1976 Oil Pressure . Harold 87 Carrera Coupe 82 911SC Coupe |
And here is Pete Zimmerman's wiki on the installation:
How-To: Replacing a 911 Cam Oil Line Adaptor - Porsche Wiki Mark
1979 911SC Targa |
Functionista
Which type of chain tensioners are in your engine? Original or later hydraulic.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Here is another thread I found later ...that I found of some of use cam oil line Restrictor/Adapter
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 07-05-2017 at 01:04 PM.. |
Try replacing the oil pressure relief cups and springs worked great for my 82sc. Easy cheap fix.
