Front suspension question
I had to cut off the tow hook on the right front retaining plate that supports the front of the A arm. The tow hook was folded over (not me, previous owner) the bolt and I wanted to remove the bar that protects the forward condenser. I removed all of the a/c a long time ago and that bar was bugging me. Can I remove the front retaining plate without messing up the alignment? If so should the car be on the ground or jacked up? I would like to grind the rest of the tow hook smooth. I was surprised how flimsy the condenser bar is, it weighs 2.5 lbs.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 07-04-2017, 08:18 PM
Slowroller's Avatar
I have an 86 and it was bent a bit by the previous owner as well. Must be common.
73T Maus
75S Targa
86 Carrera SOLD
Old 07-04-2017, 09:40 PM
Send a message via Skype™ to Porboynz
If you are concerned, make a few pencil reference marks or better still some liquid paper so you can reassemble exactly where it was
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 07-04-2017, 10:44 PM
Niels
Niels911SC's Avatar
You can remove it without messing up the alignment, but jack up the car so that the wheel on that side is in the air, that way the torsion bar won't be loaded and you can remove the three (or two remaining) bolts.
'78 911 SC Targa
Old 07-05-2017, 12:33 AM
