Now what
I misread the torque on the engine mounting bolt on my 78 sc. The passenger side stripped the threads in the mounting bar. I'm thinking I can get a grade 8 longer bolt and put a big washer and nut underneath it. Issues with doing that? Other suggestions?
Old 07-30-2017, 08:58 AM
That would suffice.
Old 07-30-2017, 09:41 AM
KNS KNS is offline
That's how it was done on the earlier cars and similar to how it is done in the water cooled 911s
Kurt
Old 07-30-2017, 10:57 AM
I twisted the ends of my carrier off as the bolts were seized in there. I replaced with a rs version and that has nut welded underneath. I would think you have a nice solution. You can put a wrench on it to tighten and loosen without twisting the carrier end.
Old 07-30-2017, 07:12 PM
sithot's Avatar
^ I'd install one of these or an equivalent. It will not twist.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 07-31-2017, 03:43 AM
