rejuvenate rubber
Whats the best products to rejuvenate the rubber on the 911 whale tail?
Brew Master
I haven't used it on a tail but I use Mothers Back To Black for the chin, smile, rear bumper guards and bumper bellows. It takes a couple of applications if it has really dulled but it's good stuff.
Vaseline.
2001 986 S |
I would try either 1Z Vinyl-Rubber Extra or 303 Aerospace Protectant.
Brew Master
Another good one to brighten faded black rubber is WD40 I use it to detail my skid steer loaders before I list them for sale. |
1987 951
Gummi Pflege works really well.
Here is a link:http://http://www.detailedimage.com/Einszett-1Z-M46/Gummi-Pflege-Stift-Rubber-Care-Stick-P474/100-ml-S1/ |
303 Aerospace is what I use as well
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
Another vote for vaseline - works a treat!
I use WüRTH Silicone Lubricating Compound, but Vaseline works just as well.
Vaseline works great. Coat it leave it in the sun 1/2-1hr than wipe it off. Lasts the summer
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
Vaseline or glycerin.
Silicone looks good in the short term, but damages/dries the rubber long term. A bad idea. |
50/50 ratio of paint thinner and boiled linseed oil
Mat P 1988 911 Carrera |
Administrator
+ 1 for Gummi Pflege Gummi Pflege IZ914806 - Einszett | Pelican Parts.
I use GM V.R.T. Vinyl, Rubber & Tire Dressing - 16oz - PelicanParts.com for my trim on my older and newer vehicles. Gives them life and also helps protect against the elements from any further damage. |
Almost Banned Once
Really? I must try this sometime.
- Peter |
303, I don't advise Vasoline on rubber or anything you want to preserve.
I had a bad experience on BMW window moldings using Vasoline.
Sold: 1989 3.2 coupe, 112k miles |
I meant Wurth...
I use it and have had no problems but tell us your experience. Might be good to know.
2001 986 S |
"It is usually not the silicone that destroys the rubber/plastic, but the carrier of the silicone (such as Hexane, Naptha... etc.) which attacks the polymer links, leaving you with a weakened material after." Still, I tend to stay away from Silicone, because it is slimy, sticky and leaves a non-wanted shine. Never been dinsappointed by cleaning the seals thoroughly and wiping some glycerine on. |
Another quote, from here:
https://www.scubaboard.com/community/threads/silicone-on-latex-seals.7645/ OK ... here's the straight skinny on silicone use for seals (Ray's deviate on OS Systems first law). Pure silicone is an excellent preservative for rubber products. It will work great on your seals and any rubber items that you own in that it seals the surface pores against air (and the rubber eating ozone in the air). Now, that said, it is very hard to find pure silicone. Most sprays or oils use a carrier or thinner that CAN damage rubber. For example, WD-40 is a silicone product, but has kerosene as a carrier so it dissolves rubber. Many (not all) of the dive industry spray silicones are a food grade (which is safe on your latex) but doesn't use a food grade carrier. |
