jarrodblake's Avatar
100mm Cap weld on bung for Center fill hood?
I am looking for a weld on bung for the VW type 1 100mm cap. That is used for the center fill hood. I already have the cap and Bowl just need the bung that the cap screws on to. It does not need to be very long as I will need to reduce it to fit my poly tank.
For reference
The tank it will be going on as you see I can not use a kit.
Old 07-26-2017, 11:31 PM
I think that the filler neck size that you need is defined as a B80 which is the minimum diameter of the bayonet fitting.
You should find one on EBay in Germany and they are manufactured by Blau.
Typical cost is less than $10.00
Old 07-27-2017, 12:16 AM
I think I found it but i'm not positive. It D 80/30 but it has a outside diameter of 105mm. I think it may be too big?
Nennmaß Innenmaß : 80 mm inner
Außenmaß : 105 mm outer
Höhe : 30 mm high
Einfüllstutzen Tankstutzen D 80/30 mit Siebauflage | eBay
Old 07-27-2017, 10:58 AM
